auxiliary reverse lights
earl964
Posted: March 11, 2008 at 4:00 PM / IP Logged
I am new to this web site and I want to ask a question. I need to install some auxiliary reverse lights on the backrack on my pickup which is a 99 Ford F-350 . I need them to come on when I switch into reverse and I also what to be able to turn them on from a switch. Someone told me I need a relay and a special switch. If someone could give me a list of materials and a diagram that would be great
Thanks for the help
United States Marine
wyatt earp
Member - Posts: 9
Posted: May 20, 2008 at 8:46 PM / IP Logged
I justed asked same question in the relay's forum.
Is your F350 a stick or auto? I'm trying to do the same thing with my 2002 Cummins Dodge (6spd manual).
Anyway, if you find something out let me know.
Wyatt Earp
Just another Diesel Performance Nut
okgearhead
Member - Posts: 9
Posted: June 16, 2008 at 1:47 PM / IP Logged
I tapped into the 7 way trailer plug, mine has a reverse light port for the trailer, that I used for the signal wire for a relay, there is a constant 12 volt there also that you will need. good luck!
hg1027
Member - Posts: 8
Posted: July 27, 2008 at 9:35 AM / IP Logged
From the few trailers I've looked at closely, there isn't a relay between the plug to the truck and the lights. Is there a reason you would need a relay when hooking up extra reverse lights on the truck?
2003 Ford F-150, soon to have the stereo on and the keys in the pocket.
Platinum - Posts: 13,723
KPierson
Platinum - Posts: 3,527
Posted: July 27, 2008 at 10:38 AM / IP Logged
auxiliary reverse lights - Last Post -- posted image.
You can do it with a relay and a switch.  Depending on how much current your reverse lights use and how big of a switch you have you may need to replace the switch with a 2nd relay.
Kevin Pierson
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
