1995 Jeep Cherokee Country Wiring Diagram
moparfreak77
Member - Posts: 14
Posted: March 02, 2003 at 11:47 AM / IP Logged
I own a '95 Jeep Cherokee Country with factory keyless entry. I bought a Prostart Model No. CT3300 and I have the auto starter hooked up but not the keyless entry. It is a pain to have the starter remote and the factory keyless one. I believe my  door locks are negative fed? Do I need relays to make this all work? I would be very thankful if someone could tell me the wires so I could hook all this up. Thanks
draasch
Gold - Posts: 2,172
Posted: March 10, 2003 at 10:05 PM / IP Logged
not sure which car you have. here are some notes. double check the wires with a meter.
Constant 12 volts RED AND RED IGN SWITCH HARNESS (BOTH 1 CIRCUIT)
Ignition 12 volts DARK BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) AT ANY PIN SWITCH OR COURTESY LIGHT
Trunk Pin Switch VIOLET / YELLOW (-) REAR PIN SWITCH OR REAR LIGHT *
Parking Lamp DARK BLUE/RED (+) AT HEADLIGHT SWITCH
Power Lock ORANGE / VIOLET DRIVER KICK #202
Power Unlock PINK/VIOLET PANEL
* GRAY (-) At Liftgate Switch, VIOLET / YELLOW (-) At Light. #202- See Positive Pulse Door Lock Diagram
these wires are for a grand cherokee
Constant 12 volts RED / WHITE FUSED AT 40 AMP AND PINK/BLACK FUSED AT 60 AMP
Ignition 12 volts DARK BLUE/GRAY IGNITION SWITCH HARNESS
Starter YELLOW/DARK BLUE IGNITION SWITCH HARNESS
Dome Light YELLOW (-) DRIVER KICK PANEL OR COURTESY LIGHT
Trunk Pin Switch GRAY/BLACK (-) LIFTGATE PIN SWITCH *
Parking Lamp DARK BLUE/RED (+) HEADLIGHT SWITCH OR AT FUSE BOX
* 1993 GRAY (-) At Liftgate Switch, VIOLET / YELLOW (-) At Light. YELLOW (-) Door Trigger Should Cover Rear Hatch On All. #202- See Positive Pulse Door Lock Diagram.
good luck,
david
moparfreak77
Member - Posts: 14
Posted: March 11, 2003 at 5:05 PM / IP Logged
thanks draasch.
