2008 cobalt, brake wire color change
Mike M2
Platinum - Posts: 2,652
Posted: March 19, 2008 at 3:52 PM / IP Logged
If anyone is interested, the brake wire color has changed from lt. blue to yellow on the new Cobalts. It's still in the same spot, BCM, lower left plug, pin 54.
Mike M2
Tech Manager
CS Dealer Services
sparkie
Platinum - Posts: 2,061
Posted: March 19, 2008 at 6:11 PM / IP Logged
You are correct about it changing, but the wire is now a Dark Green wire in the Red connector of the BCM in position A12 or a Yellow wire in A9. There is no longer a wire in position 54 in the connector where it used to be. The brake circuit only works with the ignition on.
sparky
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
