how to have led come on at set voltage?
aaronk
Member - Posts: 12
Posted: March 21, 2008 at 4:25 PM / IP Logged
Im trying to make a scaling-up shift light for my ice racer. Sometimes called a "Sequential Shift Light".
I have a tachometer signal that starts at 0.1V (idle) and ramps up to 5.0V (redline).
What Im trying to do is construct an LED shift light that will progressively light up as revs increase.
Example:
less than 4V = 0 LEDs on
4.1V = 1 LED on
4.3V = 2 LED on
4.5V = 3 LED on
.... and so on, up to 5V = all LEDs on.
The problem is how the heck to I do that?
Check this picture for an idea of what Im talking about:
how to have led come on at set voltage? - Last Post -- posted image.
Ween
Platinum - Posts: 1,368
Posted: March 21, 2008 at 7:28 PM / IP Logged
hi,
so are you looking to build a circuit yourself....google LM3914.  It's a display driver IC..and then with that IC, then look at expanded scale meters (google that also).  With some changes in resistor values you should be able to make a meter/display that starts at 4.1V and has outputs in .2V increments.  Don't worry about the piece having ten outputs, you don't need to use all of them.  you may be able to find a kit and modify values to your liking.
hope this helps
mark
aaronk
Member - Posts: 12
Posted: March 21, 2008 at 9:15 PM / IP Logged
That helps tremendously Mark.
Im on the research now and will probably be back with some application questions.
Thanks again.
aaronk
Member - Posts: 12
Posted: March 21, 2008 at 9:32 PM / IP Logged
Im going to put this link here as there is a good diagram I (or anyone else with a similar question) can use for sorting this out.
http://www.mp3car.com/vbulletin/hardware-development/88578-lm3914-led-driver-questions.html
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
