2003 Hyundai Accent GL
mazdadan
Posted: March 03, 2003 at 8:07 AM / IP Logged
Does anybody have a security system wiring diagram for a 2003 Hyundai Accent GL?  I haven't taken a look yet, so i'm not sure if it is the same as the 2002 wiring.  The main thing I am interested in is the power door lock wiring, as I'd like to wire it up for progressive unlock.  The vehicle has factory power locks.  Thanks in advance.
mazdadan
Posted: March 08, 2003 at 3:52 PM / IP Logged
FYI for everyone...I got the Alarm installed.  The 2003 Hyundai Accent has a type F lock wiring.  If you reach into the driver's kick panel and pull out the two door harnesses, one of them has a thin blue wire next to a pink wire.  The blue wire is the lock/unlock wire.  If you cut the wire it locks the doors.  If you ground the wire it unlocks them.  Since it is a one wire system, I just used a relay to interface it in.  So no actuators are needed.
