1996 fiat punto 60, alarm wiring
carlospicas
Posted: April 04, 2008 at 7:16 AM / IP Logged
Can any one tell me where do I find Wire diagram!
 I really need to install an alarm on it...
Thanks in advance...
kola7126
Copper - Posts: 93
Posted: April 08, 2008 at 3:03 PM / IP Logged
SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
www.cobra.it
Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed
as per the instructions given on the product installation manual.
fipun99gbb.doc
MAKE FIAT MOD. PUNTO YEAR 99 ® PETROL
DIESEL
ALARM/SIREN
POSITION
Position the compact alarms and the sirens in the engine compartment near the
support of the battery. Pass the cables through the original rubber sleeve near the
brake fluid reservoir.
CENTRAL UNIT POSITION Position the modular systems and the modules under the dashboard, driver’s side.
POWER SUPPLY + 30: connect to the 6 mm2 WHITE/ RED wire located in the multiway connector in
the fuse box.
- 31: connect with a ring terminal to the car body.
IGNITION WIRE + 15/54: connect to the 2 mm2 ORANGE wire located in the connector coming out
of the ignition key.
DIRECTION INDICATORS Connect to the 1 mm2 PINK and PINK/WHITE wires in the 40 way black connector
located in the front part of the fuse box.
ELECTRIC WINDOWS Controls with mixed polarity
Front window, driver’s side:
cut the 2,5 mm2 WHITE/ RED and VIOLET / YELLOW wire.
Front window, passenger’s side:
These connections should be effected in the wiring harnesses coming out of the
original switches of the windows closing.
CENTRAL DOORS LOCKING Negative control signal
Connect to the WHITE/ GREEN wire nr. 34 (lock) and light BLUE/VIOLET wire nr.
24 (unlock) in the 40 way black connector located in the front part of the fuse box.
IMMOBILISATION POINT Fuel pump
Cut the 2,5 mm2 VIOLET / YELLOW wire located in the wiring harness coming out
of the 30 way black connector in the front part of the fuse box.
STARTER +50: Cut the wire located at the position marked “+50” directly in the wiring harness
coming out of the ignition key.
BONNET SWITCH Install an additional switch on the headlamp support plate.
DOORS SWITCH For the vehicles with 2 doors: connect to the 1 mm2 light BLUE wire
(BLUE / YELLOW wire in the version with 4 doors) in the 40 way black connector
BOOT SWITCH Connect to the wire located in the wiring harness coming out of the connector of
the boot lamp.
X
