need 2007 toyota sienna alarm wiring
legenux
Copper - Posts: 92
Posted: April 07, 2008 at 2:24 PM / IP Logged
Hi, I need the 2007 Toyota Sienna LE Alarm Wiring. Anyone has it? Thanks.
Twelvoltz
Platinum - Posts: 2,384
Posted: April 09, 2008 at 9:14 PM / IP Logged
Code-Alarm/Audiovox Lists:
          #73639: 2007 TOYOTA SIENNA MINIVAN
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE/ RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
               SAME COLOR WIRE AS STARTER, BE SURE TO TEST
     Starter 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
               SAME COLOR WIRE AS IGNITION, BE SURE TO TEST
     All Door Trigger          BLUE          (-)          IGNITION SWITCH HARNESS
     Domelight Super          BLUE          (-)          IGNITION SWITCH HARNESS
     LF Latch          RED / YELLOW          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
     RF Latch          RED / YELLOW          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
     LR Latch          GRAY          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
     RR Latch          RED / WHITE          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
     Trunk Trigger          GREEN / WHITE          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
     Hood Trigger          RED / WHITE          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
     Alarm Disarm          BLUE/BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               THIS IS THE KEYSENSE WIRE
     Parking Lights          GREEN          (+)          AT UNDER DASH FUSEBOX
     Low Crr Pk Lights          GREEN/ BLACK          (-)          AT VEHICLE LIGHT SWITCH
     Convenience
     Headlights-Lo          RED / GREEN          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Headlights-Hi          RED / WHITE          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          GREEN          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          GREEN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          GREEN          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          GREEN          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          BLACK/ ORANGE          (-)          AT VEHICLE HAZARD SWITCH HARNESS
     Wipers-Lo          BLUE/BLACK          (+)          AT VEHICLE WIPER SWITCH HARNESS
     Wipers-Hi          BLUE/ORANGE          (+)          AT VEHICLE WIPER SWITCH HARNESS
     Parking Brake          RED / WHITE          (-)          AT PARKING BRAKE SWITCH
     Seat Mem 1          PINK/BLUE          (-)          AT MEMORY SEAT SWITCH
     Seat Mem 2          LIGHT GREEN/ BLACK          (-)          AT MEMORY SEAT SWITCH
     Remote Start
     Ignition 2          BLACK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          PINK          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE/BLACK          (-)          IGNITION SWITCH HARNESS
               THIS WIRE WILL ALSO DISARM THE FACTORY ALARM
     Tachometer          GREEN/ RED          (AC)          AT ECM MODULE TO RIGHT OF GLOVEBOX
     Speed Sense          VIOLET/WHITE          (AC)          AT ECM MODULE TO RIGHT OF GLOVEBOX
               ALSO IN RADIO HARNESS
     Low Crr. Pk Lights          GREEN/ BLACK          (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          GREEN / WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED / BLACK          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          GREEN/ BLACK          (+)          IGNITION SWITCH HARNESS
     IMO          BROWN / WHITE          (DATA)          AT TRANSPONDER KEY ECU ABOVE RADIO UNDER DASH
     IMI          BROWN / RED          (DATA)          AT TRANSPONDER KEY ECU ABOVE RADIO UNDER DASH
     Modules
     WIRE          LOCATION
     Module 1          ECM - BEHIND RIGHT SIDE OF DASH TO RIGHT OF GLOVEBOX
     Doorlocks/Windows
     Power Unlock          GREEN          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #12
     PowerLock          RED / YELLOW          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #9
     Driver Mtr Unlock          BLUE/RED          (REV)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Lock          WHITE/ RED          (REV)          IN HARNESS IN DRIVERS KICKPANEL
     LF Window Up          RED          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     LF Window Dn          GREEN          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Up          RED / BLUE          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Dn          BLACK/ WHITE          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Up          PINK          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Dn          BLUE/RED          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Up          RED / BLACK          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Dn          BLACK          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     Sunroof Open          RED / WHITE          (-)          AT SUNROOF SWITCH IN OVERHEAD CONSOLE
     Sunroof Close          RED / BLUE          (-)          AT SUNROOF SWITCH IN OVERHEAD CONSOLE
     Note: Code Systems makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Code Systems disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
