dei antenna module severed
Trimble Epic
Member - Posts: 20
Posted: April 19, 2008 at 10:09 AM / IP Logged
Help!
I have a DEI Python 460HP, and the remote's antenna module(Directed HF plus) was attached to the windshield.  A windshield that got cracked.  And replaced.
The auto glass installed didn't see the module attached to the old windshield, and the cable got severed right at the module.  I need to rebuild that cable and plug the module back in.  But I don't know the proper pinouts for the cable.  Which color wire connects to which pin in the module?  HELP!
Trimble
KarTuneMan
Platinum - Posts: 7,056
Posted: April 19, 2008 at 11:48 AM / IP Logged
Buy a new antenna/receiver.... what you want to do will be a headache, and after your done probly won't work . Just get a new one!
Trimble Epic
Member - Posts: 20
Posted: April 19, 2008 at 1:27 PM / IP Logged
Sounds good.  Where can I get just the cable? (or cable + antenna module) ?
chriswallace187
Gold - Posts: 1,661
Posted: April 19, 2008 at 9:28 PM / IP Logged
Check here...you can buy an XHF antenna if you'd like, they have the same plug to the alarm and are less subject to RF interference.
C Renner's Auto Electronix
Chris Luongo
Platinum - Posts: 3,746
Posted: April 20, 2008 at 7:26 AM / IP Logged
I would call the glass company and get them to make good on their mistake.
Trimble Epic
Member - Posts: 20
Posted: April 21, 2008 at 1:52 PM / IP Logged
Ouch!  Looking at the prices, I'm starting to think it's more effective to just spend the time to rebuild the cord I have.  The antenna itself is fine, just the cord got damage.  Plus, I used to build computer cables for a living, so I know my way around various crimp tools (or in this case, tweezers and my swiss army knife's tiny pliars)
Does anyone have a DEI cable they could just check the order of the colors at the antenna side of the plug?  Please?  I just need to know the pinout
Mark Mizenko
Copper - Posts: 460
Posted: April 21, 2008 at 2:31 PM / IP Logged
Looking at the BACK of the connector (the wire side)
With the two angled corners on the BOTTOM of the connector (the way it plugs into the module)
From LEFT to RIGHT            GREEN -RED- BLACK -BLUE
You may only have 3 of those wires, or all 4.
Mark Mizenko
Copper - Posts: 460
Posted: April 21, 2008 at 2:38 PM / IP Logged
Oops, I just noticed, you wanted it for the ANTENNA!
Here..
With the "U" shaped index plug on TOP of the connector
And the 4 "pin locks" on the BOTTOM of the connector......... colors are...
LEFT to RIGHT    GREEN -  RED - BLACK - BLUE
Trimble Epic
Member - Posts: 20
Posted: April 21, 2008 at 3:59 PM / IP Logged
Great! Thank you, I think I can rebuild the cable from that.  Thanks!
