08 kia spectra5 remote start
Welcome Guest :)
jsmayda
Member -
Posted: April 19, 2008 at 5:57 PM / IP Logged
Help! does anyone have a wiring diagram for this vehicle.
Thanks,
jsmayda
kola7126
Copper -
Posted: April 24, 2008 at 4:07 PM / IP Logged
| MODEL | YEAR(S) |
| SPECTRA 2.0L | 2005 - |
| KEY | T-HARNESS | IMMOBILIZER |
| N/A | N/A | KIA's TRANSPONDER ANTI-THEFT System, Requires Part #791 Bypass Module and extra Programmed Ignition Key |
| PART | COLOR | LOCATION |
| 12 VOLT CONSTANT | WHITE (+) and PINK (+) | @ IGNITION SWITCH HARNESS |
| STARTER | RED (+) | @ IGNITION SWITCH HARNESS |
| STARTER 2 | N/A | |
| IGNITION 1 | ORANGE (+) | @ IGNITION SWITCH HARNESS |
| IGNITION 2 | N/A | |
| IGNITION 3 | N/A | |
| ACCESSORY /HEATER BLOWER 1 | YELLOW (+) | @ IGNITION SWITCH HARNESS |
| ACCESSORY /HEATER BLOWER 2 | BLUE (+) | @ IGNITION SWITCH HARNESS |
| KEYSENSE | N/A | |
| PARKING LIGHTS ( - ) | GREEN (-) | @ HEADLIGHT SWITCH |
| PARKING LIGHTS ( + ) | PINK (+) Left and RED / ORANGE (+) Right, Use both!! See NOTE *1 | in DRIVERS KICK PANEL, Harness to REAR of VEHICLE |
| POWER LOCK | YELLOW/ORANGE (TYPE B) | in DRIVERS KICK PANEL, @ DOOR HARNESS |
| POWER UNLOCK | YELLOW/BLACK (TYPE B) | in DRIVERS KICK PANEL, @ DOOR HARNESS |
| DOOR TRIGGER | BLUE/BLACK (-) | in DRIVERS KICK PANEL, 8-Pin Plug |
| DOMELIGHT SUPERVISION | Use DOOR Trigger!! | |
| TRUNK RELEASE | BROWN (-) | @ TRUNK RELEASE SWITCH |
| SLIDING POWER DOOR | N/A | |
| HORN | BLUE/BLACK (-) | @ HORN SWITCH |
| TACH | YELLOW or YELLOW/ORANGE | @ IGNITION COIL |
| WAIT TO START LIGHT | N/A | |
| BRAKE | RED / BLACK (+) | @ SWITCH above BRAKE Pedal |
| FACTORY ALARM DISARM | DISARMS with FACTORY REMOTE ONLY!! | |
| ANTI-THEFT | KIA's TRANSPONDER ANTI-THEFT, System See NOTE *2 | @ IGNITION SWITCH TUMBLER |
| EXTRA INFORMATION |
| NOTE *1 The (+) Positive Parking Light Circuit on this vehicle requires (2) extra relays Part #775 to connect, See DIAGRAM NOTE *2 ONLY Canadian Model Vehicle use the TRANSPONDER System. |
Sunday, December 28, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
