91 opel vecta a
drewbu
Member - Posts: 9
Posted: April 21, 2008 at 10:17 AM / IP Logged
Hi i need wiring info on 1991 Opel Vectra A to install remote starter and alarm thanks
kola7126
Copper - Posts: 93
Posted: April 24, 2008 at 4:04 PM / IP Logged
POWER SUPPLY + 30: connect to the 3 mm 2 RED wire of the wiring harness coming out of the black connector behind the fuse box.
- 31: connect to the 4 mm2 BLACK wire located in the wiringharness coming out of the general power supply behind the left lateral bulkhead, drivers side.
IGNITION WIRE + 15/54: connect to the 1 mm 2 BLACK wire in the wiring harness along the sill cover, drivers side.
DIRECTION INDICATORS Connect to the 1 mm 2 GREEN / WHITE wires located in the wiring harness of the sill cover, passengers side.
ELECTRIC WINDOWS Comfort closing Negative control signal
Connect to the 0,5 mm 2 BROWN / BLACK wire in the wiring harness of the central door locking connector located behind the left lateral bulkhead, passengers side.
CENTRAL DOORS LOCKING Negative control signal
Connect to the 1 mm 2 BROWN / RED wire (lock) and BROWN / WHITE wire (unlock) located in the wiring harness coming out of the central connector of the
central door locking unit located behind the right bulkhead, passengers side.
IMMOBILISATION POINT Fuel pump
Connect to the 2 mm 2 RED / BLUE wire located in the wiring harness of the sill cover, drivers side.
BONNET SWITCH Install an additional switch on the lateral member, drivers side.
DOORS SWITCH Connect to the 1 mm 2 GREY wire located in the wiring harness and coming out of the connector of the central door locking unit, passengers side.
BOOT SWITCH Connect to the BROWN / WHITE wire located in the same connector of the doors wire.
X
drewbu
Member - Posts: 9
Posted: April 25, 2008 at 12:58 PM / IP Logged
thanks kola7126 or should i say "spasibo"
snoopyrider
Posted: May 09, 2008 at 3:18 PM / IP Logged
hi.
is calibra v6 from 1997 the same?i want to remote my central door system, but dont know which wire need + and wich needs - pulse to lock/unlock.would like the windows going up.thanks
