port length
sesh1975
Member - Posts: 10
Posted: April 28, 2008 at 2:40 PM / IP Logged
Hi guys! I need your help please. I have used the port calculator on this site but I want to make sure that its absolutly on the money. I have a fiberglass enclosure with 2.8 cubic feet per sub. Im going to use a 4" port and Im trying to get it tuned to 34.5Hz. What is the proper port length???
Thank you
DYohn
Platinum - Posts: 10,741
Posted: April 28, 2008 at 2:55 PM / IP Logged
The port length calculator on this site will give you accurate results.
sesh1975
Member - Posts: 10
Posted: April 28, 2008 at 3:01 PM / IP Logged
I have been getting mixed results. I have used a few other calcs and they come in at a minimum of 2 4" ports at 16" in length. Im just trying to get it right the first time.
taylormade1975
Posted: April 28, 2008 at 3:17 PM / IP Logged
 7.23565 inches long
~Wisdom is knowing what to do next; virtue is doing it.
stevdart
Platinum - Posts: 5,816
Posted: April 28, 2008 at 9:16 PM / IP Logged
You should probably arrive at port opening size of no less than one 4" port per sub (12.6 sq in), and you may need to go bigger than that.  If you are designing a dual sub enclosure, double the port opening size or double the number of ports.  Either way you do it, for the same tuning frequency the port length will calculate to roughly double the length.
According to your posts, and taylormade1975's answer, it sounds like you are getting proper results.
Note:  a 6" diameter port is more than double the opening area of a 4" port.
sesh1975
Member - Posts: 10
Posted: April 28, 2008 at 10:56 PM / IP Logged
Lets keep this easy. Im designing this for a single 12" sub. I know from the material that came with the sub that Im designing to meet the 34.5Hz. I know that my Xmax is 20.5mm. I have 2,8 cubic feet and I really only have enough room for a single port  that will run parrallel with the sub. 4" is the max diameter I can go with the port. So is the 7.2 length still correct?
daboss593
Copper - Posts: 154
Posted: April 29, 2008 at 10:16 AM / IP Logged
i just had my box made for my 1252w infinities and thought the guy messed it up. 2 cbs per sub and the vented ports are enormous as in length not diameter. but he called infinity and was assured the specs are right this is a 30-32 hz box. then again this is the 1st time ive had some decent entry lvl stuff. and not junk lol
OWWWWWWWWWWW you said you discharged the cap!
boogeyman
Silver - Posts: 359
Posted: April 29, 2008 at 9:16 PM / IP Logged
   1 sub-2.8 cubic feet - 4" port  34.5 hz = 7.23565 port length.
sesh1975
Member - Posts: 10
Posted: April 30, 2008 at 11:08 AM / IP Logged
Thank you all for the help. Finally got it figured. We can lock this one up now. '
Shawn
