08 scion xd accessory on ignition
tmrepp
Member - Posts: 19
Posted: May 05, 2008 at 1:09 PM / IP Logged
Hi all, I installed an autopage rs-1000 in a 2008 scion xD and I have everything pretty much the way I want it. One thing I would like to be able to do, is to turn the ignition to accessory (so my radio is on) without having the key in the ignition. Now, the programmable outputs are only 200mA grounded outputs, which means I probably have to use a relay to connect a solid ground, correct? Now, as to what I have to hook up, please let me know!
Thank you!
Travis
tedmond
Gold - Posts: 4,610
Posted: May 05, 2008 at 2:27 PM / IP Logged
use the aux output connected to a relay -  tag the acc wire AT THE RADIO ONLY. this allows ONLY the radio to turn on and nothing else such as HVAC system or lights.
85 - constant 12v
86 - ground output from autopage 250mA
87 - constant 12v fused @ 15 amps
30 - to radio acc wire
Radio ACC wire is GRAY (+) @ radio harness.
tmrepp
Member - Posts: 19
Posted: May 05, 2008 at 2:51 PM / IP Logged
Awesome, thank you very much. I'll let you know how it goes, off to the store for a relay!
tmrepp
Member - Posts: 19
Posted: May 05, 2008 at 4:55 PM / IP Logged
Okay, got the relay.. I don't get why you would put constant 12v into the relay twice, with only one fused.. or is 85 - constant 12v (-) and 87 - constant 12v fused @ 15amps (+)?
tmrepp
Member - Posts: 19
Posted: May 05, 2008 at 9:54 PM / IP Logged
It works, thank you very much.
chriswallace187
Gold - Posts: 1,661
Posted: May 05, 2008 at 10:47 PM / IP Logged
Basic relay stuff tmrepp - 87,87a,30 are the switched terminals, 85,86 do the switching. Read all about it on the12volt.com.
C Renner's Auto Electronix
tedmond
Gold - Posts: 4,610
Posted: May 06, 2008 at 2:24 PM / IP Logged
yeap a basic read will fill you in for sure. well now you got it working dont play the audio system you have for long periods as it stresses out the battery.
your welcome, glad to help
tmrepp
Member - Posts: 19
Posted: May 06, 2008 at 8:29 PM / IP Logged
Stock system, no subs or anything..how long do you think the battery will be okay to suffer no harm?
tedmond
Gold - Posts: 4,610
Posted: May 07, 2008 at 7:04 PM / IP Logged
if your running stock system, that is no issue.
smokescreen024
Posted: August 09, 2008 at 11:38 AM / IP Logged
I run mine for 4and a half hours  at the drive movies on a fairly regular basis with no problems stock system cranked to about 35 or 3808 scion xd accessory on ignition - Last Post -- posted image.
