autopage 750lcd power wires and misc.
bog1e
Member - Posts: 6
Posted: March 05, 2003 at 1:31 AM / IP Logged
I hope I am not becomming a nusance to you pros, but here's my questions.
98 dodge avenger es v6 w/factory alarm
1. The autopage (h1 6pin) has 2 red 12volt + inputs, am I supposed to hook up both?? If so what do I hook them up to. So far I have only hooked up one, it's hooked up to a white heavy gauge wire that always recieves 12 volts.
2. The instant trigger blue wire from h6, does it need to be hooked up?? If so can I just hook it up to the trunk light, so when someone opens the trunk it triggers the system.
3. The pink wire from h9, is this the only wire I need to use to disarm the factory keyless alarm.
hopefully someone can help me out. This is my first install, so I do have a lot of questions. Thanx guys.
floaterr
Silver - Posts: 383
Posted: March 05, 2003 at 6:00 AM / IP Logged
1) I hooked up both red to the same constant wire. No issues.
2) yes, as long as it's negative when the trunk is open
jrilla
Gold - Posts: 1,498
Posted: March 05, 2003 at 8:37 AM / IP Logged
Yes the pink wire is your factory disarm wire and it will go to the GREEN / WHITE wire in the drivers door harness. you will not be able to use drivers priority unlock feature, but that feature is annoying anyway.
You should actually have three red input wires that you can put to one 12v constant wire in the main ignition harness if that is all you have. if there are two then split the wires up. It is helpful to solder an extra wire for power in case you need it for a relay.
J Rilla
Owner/Installer
