loose vacuum line 98 safari van
rebel38317
Posted: May 13, 2008 at 11:35 PM / IP Logged
Air and heat will only blow out the defrost vents on top of the dash. I have found a loose vacuum line under the hood but cannot find a place to plug it in There is no vacuum on the line so I am assuming I am looking for a vacuum source But I can't find it .1998 Safari van with a 4.3  can anyone send me a vacuum diagram for this van?or give me a hint the vision iis limited under the hood because it is a van.
Rebel38317
My two cents
sparkie
Platinum - Posts: 2,061
Posted: May 14, 2008 at 4:15 PM / IP Logged
This is a common problem with these vans. The hard plastic vacuum line runs from the driver's side engine compartment over the hot engine to a vacuum "T" on the left side of the engine. There is vacuum reservoir mounted to the passenger side inner fender. It looks like a black palstic ball. A vacuum line runs off this to the "T" which is just beside the A/C condensor. Use rubber vacuum line to connect the two pieces. The plastic line melts on the top of the motor just forward of the throttle body. Use a light and you will find both ends of the line.
sparky
rebel38317
Posted: May 15, 2008 at 7:50 PM / IP Logged
I can't find where the hard plastic starts from on the motor ,  although I have found two more brittle broken pieces laying in front of the throttle body on top of the motor. Where did it go on the motor?
My two cents
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
