kenwood kdc-215s wiring diagram
smokie
Posted: May 24, 2008 at 9:09 PM / IP Logged
need to know were i can find a wiring diagram for a kenwood kdc-215s. any info would be greatly appreciated.
chrisglennbartlett@yahoo.com
Platinum - Posts: 13,726
Posted: May 24, 2008 at 9:55 PM / IP Logged
What color wires does it have on the unit?
smokie
Posted: May 25, 2008 at 3:56 AM / IP Logged
i know what all the wires are but 2 wires which are 1 solid blue and 1 blue with white stripe
Posted: May 25, 2008 at 5:03 AM / IP Logged
Solid blue is the power antenna wire. It's purpose is to raise the power antenna of your vehicle, if of course it is equipped with a power antenna.
The blue/white wire is your amplifier turn on lead. If you have an amplifier in the vehicle, this is the wire that tells the amp to turn on.
wvsquirrel
Gold - Posts: 1,237
Posted: May 26, 2008 at 3:37 AM / IP Logged
Here's a link to the KDC-215s manual. The wiring diagram you want is on page 20.
You need Adobe Acrobat to view the manual. You can get it here if you don't have it installed already.
Red: Switched 12v (ignition)
Yellow: Battery
Black: Ground
Blue/White: Power antenna
WHITE/ Black: Front Left -
White: Front Left +
Gray/Black: Front Right -
Gray: Front Right +
GREEN/ Black: Rear Left -
Green: Rear Left +
PURPLE / Black: Rear Right -
Purple: Rear Right +
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
