Posted: June 06, 2008 at 2:00 PM / IP Logged
Posted: June 06, 2008 at 2:19 PM / IP Logged
Posted: June 06, 2008 at 8:18 PM / IP Logged
Posted: June 07, 2008 at 5:34 PM / IP Logged
Wednesday, March 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
If your ignition is turned off, and you work the door locks, the relay should pulse and send your neg pulse.
If the ignition is on, the relay won't do anything if you hit the door locks.
One note on this: the switched 12V line you tap into has to be one of the higher draw lines, like the actual ignition, because this relies on it acting as a virtual ground for the relay. If it's a switched source that doesn't draw much power, it might not draw enough current to energize the relay.
