95 Cavalier Alarm Wiring
pilot_chris
Member - Posts: 45
Posted: March 06, 2003 at 9:52 PM / IP Logged
I'm putting in an alarm system for my Cavalier (DEI Rattler 250D) and was wondering if anyone had any helpful wiring diagrams related to my install. Thanks.
95 Cavalier 2.2L
High Output Alternator
Rockford 1 Farad Punch Capacitor
JL 500/1 for RF Punch HX2 500 watt RMS subs
MTX 4244 4 channel for Polk & Pioneer door and rear deck speakers
draasch
Gold - Posts: 2,172
Posted: March 08, 2003 at 10:04 AM / IP Logged
Constant 12 volts RED AND RED IGNITION SWITCH HARN.(BOTH 1 CIRCUIT)
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light LIGHT GREEN/ BLACK AND LIGHT BLUE (-) CONVENIENCE CNTR *
Trunk Pin Switch N/A TRUNK LIGHT HAS MERCURY SWITCH
Parking Lamp BROWN (+) DRIVER KICK PANEL
Power Lock LIGHT BLUE EITHER KICK PANEL, MUST TEST #203
Power Unlock WHITE FROM PASSENGER SWITCH
#203- See Reversal Rest At Ground Door Lock Diagram. * Conveninece Center Module Located Behind Driver Dash, Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. L GREEN/ BLACK (-) Is Driver Door, L BLUE (-) Is All Other Doors.
