fiberglass fleece
bemendozer
Member - Posts: 14
Posted: June 11, 2008 at 2:14 PM / IP Logged
What is fiberglass fleece? Is it cotton, nylon etc.
Fleece to me is wool based material, so what is the best for doing fiberglass enclosures?
DYohn
Moderator - Posts: 10,741
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: June 12, 2008 at 12:59 AM / IP Logged
I personally don't like working with fleece.  I much prefer using grill cloth to stretch with instead.  It uses quite a bit less of your expensive resin with the same results.
jvillefinest
Copper - Posts: 255
Posted: June 12, 2008 at 11:30 AM / IP Logged
Fleece or "Fiberglass" Fleece as you call it are the same thing. I prefer to start boxes with fleece because it will soak up alot of resin and dry fairly hard. then move on to the fiberglass chop mat or weave mat to do the final strengthening.
2007 Acura TSX
SQ setup in the works
bemendozer
Member - Posts: 14
Posted: June 12, 2008 at 1:00 PM / IP Logged
I think I might be confusing people with this post. What I need to know is what is the fleece made of? Cotton, Nylon etc.
DYohn
Posted: June 12, 2008 at 1:44 PM / IP Logged
T-shirt material, or bedsheets.  Cotton-polyester blend usually.
