single dvc sub on a 4 ch amp
high-fi dragon
Posted: June 27, 2008 at 7:25 PM / IP Logged
hello all first post here and i need a little help.currently i'm running a eclipse xa4000 4 channel amp on 2 older mtx 8000 10" subs.but i'm wanting to go all eclipse front to back.i already have 4" and 6 1/2 "point source and an ea4000 on them and i'm looking for a good deal on a head unit.anyways i'm wanting to put a single 12" dvc sub on the xa4000 with each coil bridged to each side of the amp.the amp's rms is 350 per side bridged.is this doable,i do not want to replace the xa4000 period or even move it to mids and highs
Platinum - Posts: 13,726
Posted: June 27, 2008 at 8:12 PM / IP Logged
Yes this is "doable" as long as you get a Dual 4 Ohm speaker.
high-fi dragon
Posted: June 27, 2008 at 8:28 PM / IP Logged
cool,thx for ths info.now i need to find that perfect dvc eclipse sub that will match the amp.any reccomendations.700 watts total 350 per side from the amp.
forbidden
Platinum - Posts: 5,354
Posted: June 28, 2008 at 5:34 PM / IP Logged
Not going to happen unless you find a older model Titanium driver. It was the only model that was dvc 4 ohm and could handle 750w rms. Look for the SW9122.
haemphyst
Platinum - Posts: 5,059
Posted: June 29, 2008 at 2:43 AM / IP Logged
Ohhhh, yeeaaahh... Even though my PERSONAL opinion is that it wanted more than 750... If you can't lay hands on an older Ti woofer, try one of these...
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
