jl 300/4 power confusion
lrdbut
Posted: June 30, 2008 at 11:51 AM / IP Logged
I have a new jl audio 300/4 v2 amp pushing a pair of 6.5 components with the front channels and pushing a sub with the two rear channels bridged. The speakers and sub are all 4-ohm. Once I got into reading the owners manual and tuning the amp (via DMM), I realized that, according to jl, I am running a "sub-optimum" configuration and the front speakers are only getting half of the amp's available power (38 instead of 75 RMS).
According to their chart, the optimum configuration for a stereo/bridged combo would be 4-ohm for the fronts and 8-ohm for the bridged rear outputs, which would give me 75X2 for the front speakers and 150X1 for the sub.
My questions are:
Should I switch out the sub for an 8-ohm version?
As an alternative, is there something I can install in-line between the amp and sub to make the amp think it's pushing 8-ohms?
Would I notice any difference anyway? (The front speakers are jl C5's and have a recommended power range from 25-75 watts RMS).
Thanks in advance.
jar754
Copper - Posts: 142
Posted: June 30, 2008 at 12:36 PM / IP Logged
depending on what type of sub do you have is it 4 ohm dvc if so how many do you have. if only 1 4dvc wire it in series to give you that 8 ohm load
lrdbut
Posted: June 30, 2008 at 2:11 PM / IP Logged
It's a 4 ohm single voice coil.
DYohn
Platinum - Posts: 10,741
Posted: June 30, 2008 at 2:32 PM / IP Logged
"Sub-optimum"?  What made you think that?  Indeed, if you refer to page 16 of your owner's manual you will find under "Optimum Configuration" stereo @ 4-ohms on channels 1 and 2 and bridged @ 4-ohms on channels 3 and 4 listed.  Just set the voltage level for those loadings per the table they give you and you are rocking.
lrdbut
Posted: June 30, 2008 at 2:50 PM / IP Logged
Hi there DYohn: My manual (Appendix C on p. 9 of 13 of the PDF version) says the optimum configuration for a stereo/bridged combo would be 4 ohms for the stereo and 8 ohms for the bridged to get the full 75/150 watts at 17.3 volts and 34.6 volts respectively. (link for the manual is http://mobile.jlaudio.com/pdfs/13192.pdf)
For the setup I have the instructions say set the front channels to 12.3 volts and the bridged rear channel to 24.6, which gives me 38 watts X 2 and 150 watts X 1.
I talked to JLand they confirmed I was reading the charts correctly and they said 38 watts was plenty to drive the speakers and I wouldn't notice the difference. That may be true but for the $ I dropped on the amp I'd kind of like to be on the 'optimum' side!
jar754
Copper - Posts: 142
Posted: June 30, 2008 at 3:26 PM / IP Logged
u wont notice the difference, but if its that big of a deal than either add another 4 ohm svc or and wire it in series, or sell what you got and get a 4 ohm dvc wire(series as well), or get a 8 ohm svc sub
DYohn
Posted: June 30, 2008 at 4:13 PM / IP Logged
Bull.  Just set it to:
Stereo side: 75 watts @ 4-ohms (17.3 volts per channel) and Bridged side 150 watts @ 4-ohms (24.6 volts)
lrdbut
Posted: June 30, 2008 at 4:42 PM / IP Logged
Yes Sir...and thanks!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
