2006 suzuki swift, keyless wiring
saboman
Posted: July 13, 2008 at 4:51 PM / IP Logged
Dear,
Who could help me with the wire diagram for this model. I need the lock/unlock wire and trunk release.
Thanks for the help
Platinum - Posts: 13,726
Posted: July 13, 2008 at 6:40 PM / IP Logged
Do you have a volt meter?   Can you easily get to the plug on the back of the trunk release button?  Is it an electric trunk release?
saboman
Posted: July 13, 2008 at 8:22 PM / IP Logged
Do you know the colors of the wires for unlocking and locking of the keyless entery. The only diagram for alarm installation for suzuki swift are till 2001 and i need one for 2006. I check the pink and pink/black as stated for 2001 but isn't the same in 2006 model and didn't got anything on the volt meter.
It's a electric trunk release, i didn't had the time to check the wire yet. I was more busy checking of the lock and unlocking wires.
Posted: July 13, 2008 at 8:40 PM / IP Logged
I have no idea what color the wires are.  How many wires are there on the trunk release button.
KarTuneMan
Platinum - Posts: 7,056
Posted: July 13, 2008 at 8:59 PM / IP Logged
If the rig doesn't have factory keyless you need to put an actuator in the drivers door. otherwise
Lock is grey/green  Unlock is YELLOW /GREEN. They are negative tyrigger. Under the pass. side dash, white plug.
saboman
Posted: July 13, 2008 at 9:09 PM / IP Logged
it does have keyless entery but couldn't get find the wires at the sidekick panel, i will check at the passenger side as you mentioned. Thanks!
saboman
Posted: July 13, 2008 at 9:21 PM / IP Logged
i did check the wide plug at the side, but there wasn't any of those color. The plug is next to an orange plug ? there was only yellow/black, grey, green, yellow/ red etc.
KarTuneMan
Posted: July 13, 2008 at 10:16 PM / IP Logged
It's a WHITE plug.. Look up under the pass. side where your toes would be if you were sitting in the seat.
