overloading an earth point
bemendozer
Member - Posts: 14
Posted: July 24, 2008 at 10:58 AM / IP Logged
Is it possible to overload an Earth Point in a car? I am wiring up a 900watt amp and rather than make an Earth Point I have found one in the back quater but it is being used by the rear lights and other small items. If I connect my amp to this earth point will it blow? I have connected the amp to this point but just to test the amp before the install went ahead and nothing blow but I don't know what will happen when the volume is turned up.
Cheers
haemphyst
Platinum - Posts: 5,059
Posted: July 24, 2008 at 12:05 PM / IP Logged
Just like ANY curent path, yes, you can "overload" it. The same as you can try to pull too much current from a battery post. This is simply an issue of excessive voltage drop. I would not use that point ever, though, as each time you step on the brake pedal, you run the risk of a "pop" from voltage or current spikes.
Find a different, and more appropriate, ground point.
eclipser93
Member - Posts: 10
Posted: July 28, 2008 at 12:08 AM / IP Logged
Well Put
