08 Ford Crown Vic Alarm Wiring Diagram
paul h
Copper - Posts: 109
Posted: August 06, 2008 at 1:00 PM / IP Logged
None of my CDs have the 08 stuff.  I have up to 07...but some of it is not matching up...so there must be some changes somewhere along the way.  Anyone help me out??  This is a police package vehicle...which I haven't seen any differences in wiring before on these...but just so it is known.
Also...what is the easiest spot to grab for the door sensors??  I'm finding the door triggers are (-) and the dome is a (+)...so what/where is the easiest place to get one of these from??
KarTuneMan
Platinum - Posts: 7,056
Posted: August 06, 2008 at 1:15 PM / IP Logged
the drivers door pin (neg)- is in a black plug in the drivers kick. the remaining 3 doors are in the running board area drivers side BROWN / orange.
to do dome light supervision tag the BLACK/ blue at the courtesy light. yes its pos. I wouldn't use this for door pins because you can shut this light OFF
with the light switch...... when its off, it's off!
paul h
Copper - Posts: 109
Posted: August 06, 2008 at 1:26 PM / IP Logged
OK, Thanks.  In the black plug, is it the small BLUE wire??  Thats what I show here....but I want to make dead sure.
And the black plug, is it a small one that shares with maybe 6 or 7 other wires..something like that??  I found the passenger wire, so I can diode isolate, no worries there....but the driver door is killing me!
Thanks for the help.
paul h
Copper - Posts: 109
Posted: August 12, 2008 at 8:45 PM / IP Logged
Bump.  Can ya'll tell me for sure if the driver door is the blue wire??  I hate testing wires...yes I'm lazy sometimes!!  HAHA  But I just like to make sure.  Thanks all....
chriswallace187
Gold - Posts: 1,661
Posted: August 12, 2008 at 11:33 PM / IP Logged
I was really tempted to suggest that the door trigger might be in the yellow sheath going up the steering column, but...
Stop being lazy. Get your meter out, and clip one end to 12 volts and the other to your suspected door trigger wire, and watch the meter as it goes from 0V with the door closed to 12V with it open.
Also FYI my info has the door triggers at the lighting control module, right of the steering column, dark blue and BLACK/ orange in the gray 22-pin connector, pins 11 and 22.
C Renner's Auto Electronix
paul h
Copper - Posts: 109
Posted: August 12, 2008 at 11:37 PM / IP Logged
Thanks for those tips...I appreciate it!!  And yeah...I was gonna get the meter out!!  HAHA  Now...one more wire I'm locating is the truck TRIGGER...not the release, but the trigger.  Mine shows up to a 07 and is a BROWN / White in the LCM and shown as a (-)??  Is that still true for the 08??
Thanks again!
KarTuneMan
Posted: August 13, 2008 at 8:13 AM / IP Logged
truck trigger?  what?08 Ford Crown Vic Alarm Wiring Diagram - Last Post -- posted image. to trigger what?  never mind!
trunk pin. BROWN / white in the drivers kick. it's negative.
