trickle charger wiring off ignition
cswminty
Member - Posts: 7
Posted: August 09, 2008 at 3:50 PM / IP Logged
i'm struggling to make sure that i wire this correctly and am not making much sense.i have a trickle charger that i want to connect to the 12v on the cigarette lighter in the car and earth too.
I want to wire it though, so that when the ignition is On, it breaks the connection between the trickle charger and the car in order to protect the alternator.
And then when the ignition is turned off, it connects the circuit again and the trickle charger supplys the circuit with a feed.
can i do this with a single relay or will i need more? and how can i wire this up ???
Chris.
Platinum - Posts: 13,718
Posted: August 09, 2008 at 9:46 PM / IP Logged
87A to the constant wire that feeds the lighter.  30 to the lighter.    85 to ground.  86 to accessory or ignition switched wire.
dualsport
Silver - Posts: 983
Posted: August 10, 2008 at 7:53 AM / IP Logged
How are you able to drive around with a trickle charger connected? Or is the car always stationary in a garage?
Wednesday, July 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
