remote start on a 1997 land rover
bigmikee
Posted: August 11, 2008 at 7:48 PM / IP Logged
Hey everyone, I'm doing a remote start on my 1997 Land Rover Range Rover 4.0SE and cannot seem to figure out as to why when i hook up the started wire and i remote start it, it keeps starting the car even when it already started. also there are two wires that start the car when i give ground to "the starter wire" and then i give ground to the ignition wire. for some reason both wire start the engine over. any one know how i can finish this remote start project would be great? thanks
mike ram
Platinum - Posts: 13,725
Posted: August 11, 2008 at 8:00 PM / IP Logged
The starting over and over thing could be caused by lack of a tachometer wire.   Following is a list of the remote start wires for your vehicle.  Look over the list and check against what you have.
remote start on a 1997 land rover - Last Post -- posted image.Battery BROWN / LIGHT GREEN (+) UNDER DR DASH OR GO TO BATTERY
remote start on a 1997 land rover - Last Post -- posted image.Ignition 1 WHITE (+) IGNITION HARNESS
remote start on a 1997 land rover - Last Post -- posted image.Accessory 1 WHITE/ PINK (-) IGNITION HARNESS
remote start on a 1997 land rover - Last Post -- posted image.Starter 1 VIOLET / YELLOW (-) IGNITION HARNESS
remote start on a 1997 land rover - Last Post -- posted image.Anti-Theft Descript NONE
remote start on a 1997 land rover - Last Post -- posted image.Tachometer WHITE STRIPE (-) DIS COIL PACK REAR OF ENG 2 CYL(INJ 1 CY
remote start on a 1997 land rover - Last Post -- posted image.Parking Lights RED (+) PLUG RIGHT OF STEERING COLUMN
remote start on a 1997 land rover - Last Post -- posted image.Brake Lights WHITE/ GRAY (+) SWITCH ABOVE BRAKE PEDAL
remote start on a 1997 land rover - Last Post -- posted image.Horn VIOLET/BROWN (-) AT BODY CONTROL MOD "BELOW PASS SEAT"
bigmikee
Posted: August 11, 2008 at 8:04 PM / IP Logged
I have all the same wires and am hooking them up the same way. but still don't get whey the ignition and the starter wire both start the engine, but they keep starting the engine even after it has started. basicly i can remote start this car with only one wire and i don't need anything else, thats weard and i don't get it. ...
mike ram
Posted: August 11, 2008 at 8:07 PM / IP Logged
Did you connect the Tachometer wire?
bigmikee
Posted: August 11, 2008 at 8:12 PM / IP Logged
yes sure am, also if i cut off the ground to any of the wire (ignition or starter) the engine cuts back off.
mike ram
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
