door chimes all the time, 06 town and country
akwormy
Member - Posts: 40
Posted: August 17, 2008 at 4:30 PM / IP Logged
Finally got the astro qs-2w (4204) installed in the 06 town and country using the pkuch2x bypass kit. Tested it all out and it's fully functioning. However....
...it acts like a key is in the ignition all the time - so any time you open a door it dings and drives you bonkers!
I know this isn't right because there's no way a customer would stand for it (and definitely no way my wife will!)
I traced it so I know what the problem is but I don't know why or how to fix it - It's the pink wire (ignition) and the violet white (mux) wire...if I remove either of those from the bypass module harness the dinging stops...
help! How do I fix the crazy dinging?
akwormy
Member - Posts: 40
Posted: August 17, 2008 at 6:41 PM / IP Logged
figured it out and fixed it - the directions that came with the PKUCH2X said that violet/white was mux....but the new directions on the website say that you cut the mux wire - ignition switch side goes to the green wire, and the BCM side goes to the violet/white wire.
problem solved - it's working great, this site was a huge help, ChrisWallace, kartuneman, and others - thanks!
KarTuneMan
Platinum - Posts: 7,056
Posted: August 17, 2008 at 10:32 PM / IP Logged
Wow.... didn't even post a reply and got a thanks..... cool, and your more than welcome my friend.
Anytime anyone posts about Astro I will try and chime in.... and I most of the time will forward it to Patrick @ Astroflex.
I love the Astro product!
akwormy
Member - Posts: 40
Posted: August 20, 2008 at 11:17 PM / IP Logged
one other question - everything is working right with the remote starter, but I've noticed since finishing it that the starter doesn't disengage as fast as it did on the suburban I took the astrostart off of.
It's not a grinding like if you hit the key while running, but the starter is staying running for a second or so after the engine fires...if there's something that will cure this I'd like to do it...
thanks!
KPierson
Platinum - Posts: 3,527
Posted: August 21, 2008 at 6:00 AM / IP Logged
Did you reprogram the tach signal for the new vehicle?
Kevin Pierson
akwormy
Member - Posts: 40
Posted: August 21, 2008 at 4:52 PM / IP Logged
I did - as a 6cyl with 800 rpm...I didn't try the autotach as I read about some problems with it failing after a while. I can double check the programming though if that could be a possible cause. (it wouldn't run at all if I failed to get a proper tach signal from the coil correct?)
I also noticed my hood switch isn't killing the engine (and it was at one point)...guess I need to see if I reprogrammed it or my switch has gone bad or what...
gremechar
Member - Posts: 8
Posted: August 23, 2008 at 4:13 AM / IP Logged
I'm installing the basic alarm without remote start and starter kill
