remote start 99 tahoe
doggworld1233
Member - Posts: 16
Posted: August 19, 2008 at 5:59 PM / IP Logged
alarm autopage rs 727
car is a 99 tahoe
used i data link bypass.
problem is car will start then the starter will continue to run. i programed the tach sig 3 times by on/off 3 time then vallet 11 times holding on the 11th then holding lock and unlock then pressing unlock then starting the car then pressing the vallet button then turning off the car and pressing lock to exit.
thanks in adv for any help.
doggworld1233
Member - Posts: 16
Posted: August 20, 2008 at 6:00 AM / IP Logged
i really need some help!!
jmsounds
Copper - Posts: 99
Posted: August 20, 2008 at 4:08 PM / IP Logged
where did you get the tach wire  did u use data  because you can get it at the bcm in the engine compartment
the reason why the starter still run after starts is due to lack of tach signal  get the right wire  white use a dmm  and it should read around 6 volts ac  good luck
kgerry
Platinum - Posts: 3,455
Posted: August 20, 2008 at 4:25 PM / IP Logged
you can grab tach under the hood or at the cluster....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
