Wiring diagram for 2003 Honda Element
mike1007
Posted: March 11, 2003 at 11:23 AM / IP Logged
Anyone have this information yet?  Also will the 555H OEM by-pass work for the element.
Platinum - Posts: 12,488
Posted: March 11, 2003 at 3:31 PM / IP Logged
The 555H will not work on the Element. You need to use a 555U for this vehicle.
Here's the wiring diagram:
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ red           |+  |ignition harness            |
|       POWER LOCK|WHITE/ blue          |-  |gray plug above drivers kick|
|     POWER UNLOCK|WHITE/ green         |-  |gray plug above drivers kick|
|       LOCK MOTOR|yellow/black        |   |driver kick panel           |
|     UNLOCK MOTOR|YELLOW /GREEN        |   |driver kick panel           |
|    DISARM DEFEAT|yellow              |   |passenger kick panel        |
| PARKING LIGHTS +|RED / black           |   |driver kick panel           |
| PARKING LIGHTS -|blue                |   |factory alarm plug *1       |
|       HEADLIGHTS|blue/red            |-  |factory alarm plug *1       |
|     DOOR TRIGGER|*2                  |-  |factory alarm plug *1       |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|red                 |-  |factory alarm plug *1       |
|         HOOD PIN|yellow/red          |-  |factory alarm plug *1       |
|TRNK/HTCH RELEASE|BLACK / YELLOW        |-  |driver kick panel           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|blue                |   |test connector *3           |
|      SPEED SENSE|blue/white          |   |cruise control module *4    |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|orange              |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|-  |steering column             |
|  LF WINDOW UP/DN|RED / blk - RED / yel   |A  |driver window switch        |
|  RF WINDOW UP/DN|blu/red - blu/wht   |A  |driver kick panel           |
|  LR WINDOW UP/DN|blu/blk - brown     |A  |driver kick panel           |
|  RR WINDOW UP/DN|blu/org - blu/yel   |A  |driver kick panel           |
| SUN RF OPN/CLOSE|grn/yel - grn/blk   |A  |relays above driver kick    |
|        RADIO 12V|WHITE/ red           |+  |radio                       |
|     RADIO GROUND|black               |+  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|       LF SPEAKER|grn/blk - lt green  |   |radio                       |
|       RF SPEAKER|grn/yel - gry/red   |   |radio                       |
|       LR SPEAKER|blu/wht - blu/blk   |   |radio                       |
|       RR SPEAKER|pink - blu/yel      |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555U.  *1 The factory alarm plug is a green plug to the left of the steering column.  *2 The drivers door trigger is green, and the passenger door trigger is lt. GREEN/ black.  Use both and diode isolate each.  *3 The test connector is next to the battery.  *4 The cruise control module is to the left of the steering column.
Bnluis
Silver - Posts: 578
Posted: March 11, 2003 at 3:35 PM / IP Logged
|              12V|                    |   |                            |
|          STARTER|BLACK/ white         |   |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|BLACK / YELLOW        |   |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|yellow or blue      |   |ignition harness            |
| SECOND ACCESSORY|WHITE/ black         |   |ignition harness            |
|       POWER LOCK|add actuator *1     |   |in driver door              |
|     POWER UNLOCK|add actuator        |   |in driver door              |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|grn/yel & grn/blu   |   |blu 16 pin conn under column|
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|BLACK/ WHITE/ silver  |-  |brn 14 pin conn under column|
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |   |grn 16 pin conn under column|
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|       TACHOMETER|blue                |   |at the distributor          |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|                    |   |                            |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blu/yel - blu/grn   |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|grn/red - grn/yel   |   |sunroof motor               |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
*1 CDL maybe neg. trip on BLACK/ white & BLACK/ red.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
mike1007
Posted: March 12, 2003 at 6:23 AM / IP Logged
Great!!, thanks alot guys.
Posted: March 13, 2003 at 4:45 PM / IP Logged
No problemo
