99 pathfinder issues
saskpuller
Copper - Posts: 144
Posted: September 14, 2008 at 9:41 PM / IP Logged
Installed a RS into a 99 Pathfinder last year for a customer that had sinced moved away. He returned this past weekend to say that he has issues.  The starter portion works fine and the door locks work fine. Problem arises when he locks the door with the power switch on the door and then uses the RS remote to open the door. The alarm goes off and the only way to shut it off is by putting the key in the door and unlocking it. Obviously I missed something somewhere but what. My info shows no disarm wire of any sort.
Platinum - Posts: 13,725
Posted: September 14, 2008 at 10:02 PM / IP Logged
     Alarm Disarm          LIGHT GREEN          (-)          SEC MODULE RIGHT OF COLUMN
saskpuller
Copper - Posts: 144
Posted: September 16, 2008 at 12:19 AM / IP Logged
So this should fix the problem of alarm sounding when unlocking with the remote after locking with the door switch?
kgerry
Platinum - Posts: 3,455
Posted: September 18, 2008 at 12:39 PM / IP Logged
yep.. assuming your unit is programmed for FAD on unlock.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
saskpuller
Copper - Posts: 144
Posted: September 21, 2008 at 10:19 PM / IP Logged
What is FAD?
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
