1998 eclipse alarm and remot stater troub
hotrod540
Posted: September 15, 2008 at 3:11 PM / IP Logged
hey guys i picked up a 1998 eclipse 2.0 auto tranny  as a project it had half a alarm and remot starter system parts were missing so i took the rest off im think it must have had a stater killer on it cause when u turn key to start the starter relay on the firewall clicks but theere is no power to the starter silonod i have looked under steering colum to see if i could see any wire that had been cut but i cant seem to find any there is 2 conectors that look to be factory but r not plugged in i know the small one has to do with door locks using test u can make locks click the bigger one has like 4 or 5 wires have  no ideal what it does and there is also a little push bottun these are all running together i dont know if they had to take something factory off to make alarm work if anyone has any ideals of what im over looking or where to look or what color wires i need to be looking for thanks for any help
hotrod540
ckeeler
Gold - Posts: 1,461
Posted: October 02, 2008 at 4:03 PM / IP Logged
can you post a picture of what your looking at/talking about?
Posted: October 02, 2008 at 4:55 PM / IP Logged
Sounds like you are looking at the plug from an alarm module either factory or aftermarket. Trace the starter lead from the ignition switch ,also look to see if the starter circuit is fused anywhere and if there is a starter relay.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
