remote start, transmitter no longer chirps
dru500a
Posted: September 24, 2008 at 2:38 AM / IP Logged
Hi, hope someone can help. I have an 03 accord that has an Audiovox Prestige remote start/alarm system installed. The problem I'm having is that the system and remote no longer chirps. It does occassionally. It normally gives a confirmation chirp or chirps upon arming or unlocking or starting the engine. Anyone know what can be causing this?
dru500a
Posted: September 24, 2008 at 2:41 AM / IP Logged
Sorry, just to clarify, I believe the system I have is the APS-995 or APS-996. The transmitter I have is the 5BCR. I hope this helps. I am not too knowledgeable in these matters. Thanks for your help in advance.
Mike M2
Platinum - Posts: 2,652
Posted: September 24, 2008 at 6:37 AM / IP Logged
It could be you turned the chirps off by mistake. Try key on, key off, press valet button 3 times. Also, if it's in valet it woun't chirp. Is the lED lit solid when you turn the key on?
Mike M2
Tech Manager
CS Dealer Services
dru500a
Posted: September 26, 2008 at 11:44 AM / IP Logged
Thx, I will try per your suggestions when I get my car back tomorrow. Unfortunately, my remote has been through some tough times and I won't be able to tell you if the light will be lit solid.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 26, 2008 at 1:12 PM / IP Logged
He's talking about the LED drilled into the car's dashboard, the one that flashes when the alarm is armed.
dru500a
Posted: September 28, 2008 at 6:17 PM / IP Logged
Hey guys, thanks for the help. I went through the process of turning key on, off, then button 3 times and the sound system chirps as it normally did. However, the transmitter (remote) still doesn't chime. I replaced the battery and upon putting the new battery in, the transmitter chimes so the speaker is not broken. It doesn't chime to confirm lock, unlock, etc. I've looked at the manual but can't find the answer. What do you guys think?
