08 taurus add on alarm
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 08 taurus add on alarm (
Topic Closed)
Welcome Guest :)
Posted: October 07, 2008 at 11:47 AM / IP Logged
looking for info on wiring for 08 taurus. having problems finding the keyless only wiring for an add on alarm; the wires that control only the keyless and not just the door switches. been thru audiovox wiring to no avail.Old School Funkster
Posted: October 15, 2008 at 10:35 PM / IP Logged
Unlock is yellow / purple and negative trigger
Lock is Blue / green
heres the rest of the info on your car if u need it
2008 Ford Taurus DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts red (80A) + SJB, 1 pin plug (G), pin 1
The SJB (Smart Junction Box) is the fuse box under the driver side dash.
Second 12 Volts red (20A) + ignition switch, 7 pin plug, pin 4
Starter blue/white + ignition switch, 7 pin plug, pin 7
Second Starter N/A
Ignition WHITE/ orange + ignition switch, 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory PURPLE / green + ignition switch, 7 pin plug, pin 6
Second Accessory N/A
Third Accessory N/A
Keysense blue/gray + ignition switch, 7 pin plug, pin 5
Data Bus yellow/orange (TX), PURPLE / gray (RX) data PATS Transceiver, 4 pin plug, pins 3 (TX), 4 (RX)
The PATS (Passive Anti-Theft System) Transceiver is around the ignition key cylinder. The PATS ignition wire is blue/brown in pin 1 and the ground wire is BLACK/ blue in pin 2.
Can Bus High gray/orange data data link connector under driver dash, pin 3
Can Bus Low PURPLE / orange data data link connector under driver dash, pin 11
Can Bus Sw N/A
Power Lock blue/green - driver kick or SJB, 26 pin plug (C), pin 17
Power Unlock yellow/purple - driver kick or SJB, 26 pin plug (C), pin 4
Lock Motor gray/brown 5 wire driver kick or SJB, 32 pin plug (D), pin 6
Driver Unlock Motor blue/green 5 wire driver kick or SJB, 32 pin plug (D), pin 28
Passenger Unlock Motor PURPLE / gray 5 wire driver kick or SJB, 32 pin plug (D), pin 27
Parking Lights (-) gray - headlight switch or SJB, 52 pin plug (B), pin 31
The SJB (Smart Junction Box) is the fuse box under the driver side dash. May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ blue at the headlight switch, 10 pin plug, pin 7. See Tech Doc 1096 for wiring information.
Parking Lights (+) purple or PURPLE / white + driver kick or SJB, 32 pin plug (D), pin 20
Hazards BROWN / yellow - hazard switch or SJB, 52 pin plug (B), pin 48
Turn Signal (Left) blue/green (F); gray/brown (R) + SJB, 26 pin plug (F), pin 21; 32 pin plug (D), pin 25
Turn Signal (Right) yellow/purple (F); PURPLE / orange (R) + SJB, 26 pin plug (F), pin 23; 32 pin plug (D), pin 26
Headlight blue/white - headlight switch or SJB, 52 pin plug (B), pin 30
AutoLights PURPLE / green - headlight switch or SJB, 52 pin plug (B), pin 50
Reverse Light GREEN/ brown + driver kick, harness to rear
Left Front Door Trigger GREEN/ purple - N.C. driver kick or SJB, 26 pin plug (C), pin 14
Right Front Door Trigger white - N.C. passenger kick or SJB, 26 pin plug (C), pin 2
Left Rear Door Trigger green - N.C. driver kick or SJB, 26 pin plug (C), pin 3
Right Rear Door Trigger yellow - N.C. passenger kick or SJB, 26 pin plug (C), pin 15
Dome Supervision gray/purple + driver kick or SJB, 14 pin plug (A), pin 9
The SJB (Smart Junction Box) is the fuse box under the driver side dash. Also found in the driver A pillar. The exterior mirror puddle lamps wire is purple (+) in the driver kick, door harness or at the SJB, 26 pin plug (C), pin 12.
Trunk/Hatch Pin gray/orange - N.C. driver kick or SJB, 26 pin plug (C), pin 16
Rear Glass Pin N/A
Hood Pin blue/orange - N.C. hood pin switch or SJB, 26 pin plug (F), pin 10
Trunk/Hatch Release brown - release switch or SJB, 26 pin plug (C), pin 20
Trunk Release Motor BROWN / blue + driver kick or SJB, 32 pin plug (D), pin 31
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm GREEN/ purple - driver kick or SJB, 26 pin plug (C), pin 8
Meter this wire while turning the key in the driver door key cylinder. The SJB (Smart Junction Box) is the fuse box under the driver side dash.
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt N/A
Tachometer NOT blue ac any fuel injector
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Fuel Pump PURPLE / green or PURPLE / white + inertia fuel shutoff switch in passenger kick
Rear Defroster WHITE/ orange - latched HVAC Control Module in dash
On vehicles with manual A/C, it is in the 26 pin plug (A), pin 3. On vehicles with automatic A/C, it is in the 26 pin plug (B), pin 23. Also found in a junction connector to the left of the steering column, pin 2.
Mirror Defroster same as rear defroster
Left Front Heated Seat WHITE/ blue passenger kick or HVAC Module, 26 pin plug (B), pin 6
Right Front Heated Seat gray / YELLOW passenger kick or HVAC Module, 26 pin plug (B), pin 3
Speed Sense BROWN / green ac PCM, plug towards driver side, pin 14
The PCM (Powertrain Control Module) is under the hood, on the passenger side firewall.
Brake Wire PURPLE / white + switch, dr kick, or SJB, 52 pin plug (B), pin 40
Parking Brake WHITE/ purple - parking brake switch or SJB, 26 pin plug (C), pin 1
Horn Trigger blue/white - horn switch or SJB, 52 pin plug (B), pin 41
Wipers blue/orange (L), PURPLE / orange (H) - windshield wiper switch, 16 pin plug, pins 16 and 9
Left Front Window (Up/Down) motor part of module
Right Front Window (Up/Down) BROWN / yellow - GREEN/ orange A driver kick, door harness
Left Rear Window (Up/Down) blue/orange - yellow A driver kick, door harness
Right Rear Window (Up/Down) gray/purple - BROWN / green A driver kick, door harness
Sun Roof (Open/Close) motor part of module
Sun Roof (Limit/Close) N/A
Memory Seat 1 PURPLE / white - driver kick, harness to rear
Memory Seat 2 yellow - driver kick, harness to rear
Memory Seat 3 N/A
Radio 12V WHITE/ red + radio, 24 pin plug, pin 1
Radio Ground BLACK/ blue - radio, 24 pin plug, pin 13
Radio Ignition blue + radio, 24 pin plug, pin 2
Radio Illumination N/A
Factory Amp Turn-on PURPLE / red (sub amp) + radio, 8 pin plug, pin 4
Power Antenna YELLOW /GREEN + radio, 24 pin plug, pin 5
Left Front Speaker (+/-) white - WHITE/ brown +,- radio, 24 pin plug, pins 8 and 21
Right Front Speaker (+/-) WHITE/ purple - WHITE/ orange +,- radio, 24 pin plug, pins 11 and 12
Left Rear Speaker (+/-) WHITE/ green - BROWN / yellow +,- radio, 24 pin plug, pins 9 and 22
Right Rear Speaker (+/-) BROWN / white - BROWN / blue +,- radio, 24 pin plug, pins 10 and 23
Center Channel (+/-) N/A
Subwoofer (+/-) PURPLE / green - GREEN / WHITE +,- radio, 8 pin plug, pins 1 and 2
Aux. Audio Input Left (+/-) blue - YELLOW /GREEN +,- radio, 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-) blue/green - WHITE/ green +,- radio, 16 pin plug, pins 6 and 14
RSE Video (+/-)
RSE Audio Left (+/-) GREEN/ orange - blue/brown +,- radio, 16 pin plug, pins 1 and 2
RSE Audio Right (+/-) PURPLE / brown - yellow/blue +,- radio, 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts blue/red + satellite radio receiver in driver side trunk
Satellite Radio Ground BLACK/ blue - satellite radio receiver in driver side trunk
Satellite Radio Ignition (CAN data bus)
Satellite Radio Antenna (coaxial cable)
Satellite Audio Left (+/-) GREEN/ orange - blue/brown +,- satellite radio receiver in driver side trunk
Satellite Audio Right (+/-) PURPLE / brown - yellow/blue +,- satellite radio receiver in driver side trunk
Item Size Depth Location
Headunit double DIN center of dash
Left Front Speaker 6 x 8 left front door
Left Front Tweeter N/A
Right Front Speaker 6 x 8 right front door
Right Front Tweeter N/A
Left Rear Speaker 6 x 8 left rear door
Left Rear Tweeter N/A
Right Rear Speaker 6 x 8 right rear door
Right Rear Tweeter N/A
Center Channel N/A
Subwoofer 6 x 9 (x2) rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner driver side trunk
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU Module Description Upgradeable Keys Required for Programming Keys Required for Operation
XK04 Programmable Platform #04: Ford PATS Override Interface / Firmware: PKFORD 3.00 Yes 2 0
556SW FORD PATS3 SECURILOCK RF TRANSPONDER BYPASSKIT chip '01-08 No 2 0
© 2007 Directed Electronics. All Rights Reserved.
DirectWire and its vehicle information are for the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
"JT" Advanced Certified installer for Sound Sensations in Marietta,GA
Sunday, March 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
