audiovox awm930 in rv
hbbyhorse
Posted: October 11, 2008 at 12:08 AM / IP Logged
Hi
Need help in wiring this wall mount stereo system in a 5th wheel camper. Have 3 wires out of stereo, 12vDC Ignition power, 12vDC Battery power and the ground wire, but only have 2 wires in trailer where stereo used to be, one wire is blue (power) other wire is white (ground), When I have just the battery and the ground hooked up, the clock is on, but does not power on .... what I doing wrong?
Thx
haemphyst
Platinum - Posts: 5,059
Posted: October 11, 2008 at 12:22 AM / IP Logged
You connect both of the power (red and yellow) wires to the blue wire. This means the device will ALWAYS have the possibility of being left on, so you have to be certain you power it off whenever there is no charging device connected to your storage device.
hbbyhorse
Posted: October 11, 2008 at 8:48 AM / IP Logged
thank you :-)
I'll give it a try
