94 dodge ram tach hook up
jesse360
Posted: October 15, 2008 at 9:29 PM / IP Logged
so i bought a 94 ram 1500 and it didnt have a tachometer so i went to a junk yard and picked up a used gauge cluster with tach out of a 96 ram and the tach will not work when installed ...something with the pcm but im not exactly sure
thanks jesse
ckeeler
Gold - Posts: 1,461
Posted: October 16, 2008 at 12:34 PM / IP Logged
so you installed the used instrument cluster right in place of the old one and just pluged it in right? but do you know if there is even a tach wire in the plug of the instrument cluster for your truck or not? have you tested for and found it there?
chriswallace187
Gold - Posts: 1,661
Posted: October 16, 2008 at 2:28 PM / IP Logged
You need to get information on the pinout of the cluster connector(s). They aren't necessarily the same between different trim levels/models of that truck, regardless of whether the connectors plug in.
For that info, you could use ALLDATA or Mitchell's online DIY services, or possibly a paper Chilton/Haynes manual.
C Renner's Auto Electronix
ckeeler
Gold - Posts: 1,461
Posted: October 16, 2008 at 2:38 PM / IP Logged
chriswallace187 is absolutly correct. thats why i asked the above question. because the wire you need to make the tach work may not be there. you may have to run one.
jesse360
Posted: October 16, 2008 at 3:31 PM / IP Logged
ya i heard that the tac wire was in the bundle but it might just be disconnected or something
thanks jesse
jesse360
Posted: October 16, 2008 at 3:37 PM / IP Logged
allright thanks for the advice ...if i have to run a wire would i have to run it to the tach or into the plug?
thanks jesse
ckeeler
Gold - Posts: 1,461
Posted: October 16, 2008 at 3:48 PM / IP Logged
you would have to go to the plug at the back of the instrument panel.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
