2008 chevrolet upland wiring
caddyroger
Member - Posts: 6
Posted: October 18, 2008 at 5:35 PM / IP Logged
On a 2008 Chevy Uplander all of the wiring is 16 some 14 ga. On the wiring diagram the starter wire is yellow. The yellow goes from the ing switch to the BCM and is only 16g. How would you test this wire? Does the switch makes ground? Would this be the same for the ass and ign wie?
Caddy
Platinum - Posts: 13,725
Posted: October 19, 2008 at 8:01 PM / IP Logged
2008 chevrolet upland wiring - Last Post -- posted image.BatteryRED(+)AT VEHICLE BATTERY
2008 chevrolet upland wiring - Last Post -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
2008 chevrolet upland wiring - Last Post -- posted image.Accessory 1BROWN(+)IGNITION SWITCH HARNESS
2008 chevrolet upland wiring - Last Post -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
2008 chevrolet upland wiring - Last Post -- posted image.Anti-Theft TypeGM PASSKEY III® VEHICLE IMMOBILIZER
2008 chevrolet upland wiring - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2008 chevrolet upland wiring - Last Post -- posted image.Key SenseLIGHT GREEN(-)IGNITION SWITCH HARNESS
2008 chevrolet upland wiring - Last Post -- posted image.TachometerTAN(AC)AT PCM MODULE INSIDE AIR CLEANER ASSEMBLY
2008 chevrolet upland wiring - Last Post -- posted image.Crankshaft SensorLIGHT BLUE/WHITE(AC)AT PCM MODULE UNDER AIR CLEANER UNDER HOOD2008 chevrolet upland wiring - Last Post -- posted image.
2008 chevrolet upland wiring - Last Post -- posted image.Camshaft SensorBROWN / WHITE(AC)AT PCM MODULE UNDER AIR CLEANER UNDER HOOD2008 chevrolet upland wiring - Last Post -- posted image.
2008 chevrolet upland wiring - Last Post -- posted image.Speed SenseDARK GREEN(AC)RADIO HARNESS2008 chevrolet upland wiring - Last Post -- posted image.
2008 chevrolet upland wiring - Last Post -- posted image.Parking LightsBROWN / WHITE(-)AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH2008 chevrolet upland wiring - Last Post -- posted image.
2008 chevrolet upland wiring - Last Post -- posted image.Brake LightsWHITE(+)AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH2008 chevrolet upland wiring - Last Post -- posted image.
2008 chevrolet upland wiring - Last Post -- posted image.Reverse LightsLIGHT GREEN(+)AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH2008 chevrolet upland wiring - Last Post -- posted image.
2008 chevrolet upland wiring - Last Post -- posted image.HornTAN(-)AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
According to the info above the start wire is Positive.
caddyroger
Member - Posts: 6
Posted: October 19, 2008 at 9:06 PM / IP Logged
The pink, brown and the yellow wires are 16 gage. When I connect a test light from the yellow to ground I do not show any voltage when the key is in the start prosition.
Caddy
Posted: October 19, 2008 at 9:50 PM / IP Logged
You really do not need to be using a test light in a newer vehicle. Did the vehicle turn over when you were testing it with the test light?
caddyroger
Member - Posts: 6
Posted: October 19, 2008 at 10:17 PM / IP Logged
Nothing. Maybe this week end I'll retest using my voltmeter. I wish I could find the wiring diagram for the Van. The chiltons, alldated do not have the 2008 Uplander listed.
Caddy
