f250 power door lock woes
modmotor1
Posted: October 22, 2008 at 12:28 PM / IP Logged
Hey guys thanks in advance but heres the skinny on what i have:
2006 super duty with keyless entry...... viper 771xv remote start etc....... i have the DEI 451m and thats what i have problems with
1. I hooked up 451m as follows
I cut the pink with white wire in drivers kick panel that showed +polarity with door lock and the black with white.
The voilet/blck went to 12 constant which is 87 on 451M
gr/bl lock output (30) i connected to the side of the black wire that showed 12v when the switch was closed (blck/white going up the harness towards door)
wh/blck (87a) i connected to the other side of the cut blc/white
blu/blck unlock output (30) went to pink/white that showed power when switch was closed (wire headed up harness towards door)
br/blck unlock output (87a) went to the other side of pink/white
2. When i push lock (or unlock) i have polarity coming out of 451m as i should have on both 30's but the doors do not lock or unlock
3. Even if i power probe the wires that show polarity when the lock button on the vehicle is closed the locks dont open or close either.
4. When i use viper keyless fob i feel the contacts inside switching so i feel that up to there i am good with my wiring as i have 12v on both 30's when its called for.
What step did i skip? i followed the directions to a T but maybe there is something else i am missing? Do i need to bypass these connections and go straight to the door actuator?
ckeeler
Gold - Posts: 1,461
Posted: October 22, 2008 at 12:34 PM / IP Logged
they still work with the switch right?
modmotor1
Posted: October 22, 2008 at 12:36 PM / IP Logged
yup....... switch, outside keypad, and factory keyless entry still work.......... any ideas?
ckeeler
Gold - Posts: 1,461
Posted: October 22, 2008 at 12:39 PM / IP Logged
yep i know what it is. ive run into this on these ford supers before. pm me
mikvot
Gold - Posts: 1,043
Posted: October 22, 2008 at 1:22 PM / IP Logged
If the truck has factory keyless, then the BLACK/ white, and WHITE/ red are (-) doorlock wires. You do not need to cut these 2 wires. On the 451 m, the violet/ black goes to ground, not 12 volts. 30 GREEN/ black will go to the BLACK/ white of the truck. 30 blue/black will go to the WHITE/ red of the truck.
modmotor1
Posted: October 22, 2008 at 4:22 PM / IP Logged
U guys are the best!!! I will try this out later and get back.......... i figured this was something stupid and the viper EXPERTS at their HQ are no help
modmotor1
Posted: October 22, 2008 at 6:33 PM / IP Logged
That worked thanks a million!!! problem solved..... it doesnt work progressively but i dont really care about that just as long as the doors unlock!! you guys are the best
