viper 5701, 89 vw vanagon
mk1coupe
Posted: November 01, 2008 at 1:29 PM / IP Logged
i am putting in a remote start/car alarm (Viper 5701) in my 89 VW Vanagon. i beileve it has 3 wire locks, will i need relays to drive these locks or can i just use the output from the alarm?
thanks.
mk1coupe
Posted: November 01, 2008 at 2:20 PM / IP Logged
i have read the install manual a couple time now and need a little help please.
Q. there is a wire called "Light Flash - isolation wire - pin 87a of onboard relay"
i assume this will flash my parking lights?
there is also a wire called "parking light output" what is this for? do i connect both?
Q2. i have ground trigger door switches installed in the van. and i know what wire to connect them to on the alarm but there is also a "(-)200mA dome light output". can i connect these to the same wire? as the dome light is driven off the grounding door switch..
TIA
mk1coupe
Posted: November 01, 2008 at 2:21 PM / IP Logged
does anyone know if these are 3 wire or vacuum? where the relays are in a vanagon?
brhaugen
Copper - Posts: 275
Posted: November 01, 2008 at 10:18 PM / IP Logged
My info says to add an actuator to the drivers door.
Brent Haugen
Fargo, ND
mk1coupe
Posted: November 02, 2008 at 1:13 AM / IP Logged
that means 2 relays AND another actuator.
cant it be done with just the relays?
brhaugen
Copper - Posts: 275
Posted: November 02, 2008 at 7:09 AM / IP Logged
It says add an actuator - that is all it says.
Yes, you need relays - you should be able to find a diagram in the "diagrams" section under door locks.
Never done one - sorry.
Brent Haugen
Fargo, ND
mk1coupe
Posted: November 02, 2008 at 11:20 AM / IP Logged
any tips on where to buy relays and actuators online?
JWorm
Platinum - Posts: 2,208
Posted: November 02, 2008 at 5:36 PM / IP Logged
PartsExpress.com
