2003 ford f150 vss
absolutepower
Copper - Posts: 98
Posted: November 01, 2008 at 3:48 PM / IP Logged
putting nav in f150 and i do not have any idea where to find the vss other that the speedometer it self if anyone can throw me some ideas where it might be located that would be dope. let me know
Platinum - Posts: 13,725
Posted: November 01, 2008 at 8:25 PM / IP Logged
I have no idea where the PCM is located in that truck but it has a 104 pin plug connected to it.  If you find that module, the following will help you.
2003 ford f150 vss - Last Post -- posted image.BatteryYELLOW(+)IGNITION SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.Ignition 1DRK.BLUE/LIGHT GREEN(+)AND BLU/GRN AT IGN SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.Ignition 2GRAY / YELLOW(+)IGNITION SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.Ignition 3RED / BLACK(+)IGNITION SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.Accessory 1BLACK/ LIGHT GREE(+)IGNITION SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.Starter 1RED / LIGHT BLUE(+)IGNITION SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.Anti-Theft TypeUNDER DASH PAD
2003 ford f150 vss - Last Post -- posted image.Anti-Theft DescriptPATS
2003 ford f150 vss - Last Post -- posted image.Key SenseBLACK/ PINK(+)STEERING COLUMN HARNESS
2003 ford f150 vss - Last Post -- posted image.Neutral SafetyRED / LIGHT BLUE(+)IGNITION SWITCH HARNESS
2003 ford f150 vss - Last Post -- posted image.TachometerLIGHT GREEN / WHITE(-)AT PCM PIN 26 OF 104 CONN.
2003 ford f150 vss - Last Post -- posted image.Crankshaft SensorGRAY(+)PIN 26 OF 104 CONN. AT PCM
2003 ford f150 vss - Last Post -- posted image.Camshaft SensorDARK GREEN(+)PIN 22 OF 104 CONN. AT PCM
2003 ford f150 vss - Last Post -- posted image.Speed SenseGRAY/BLACK(AC)PIN 68 OR 58 AT PCM
2003 ford f150 vss - Last Post -- posted image.Parking LightsBROWN(+)AT HEAD LIGHT SWITCH
2003 ford f150 vss - Last Post -- posted image.Brake LightsLIGHT GREEN(+)AT BRAKE SWITCH
2003 ford f150 vss - Last Post -- posted image.Reverse LightsBLACK/ PINK(+)AT HARNESS TO REAR OR AT SEC. MODULE
2003 ford f150 vss - Last Post -- posted image.HornDARK/BLUE(-)STEERING COLUMN
extreme1
Silver - Posts: 1,070
Posted: November 02, 2008 at 12:41 AM / IP Logged
does your stock radio have two plugs?
if so it's grey/black at the second plug.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
