561t and xk05 pkt2
new_leaner
Member - Posts: 14
Posted: November 07, 2008 at 11:14 AM / IP Logged
Hi everybody,
I am trying to install 561t RS and XK05(pkt2) to 2002 honda accord with factory alarm, but I don't know how to connect these wires:
-   (H1/3) Yellow Ignition Output to RF system
-   (Brown) Ground when running Input of XK05
thanks for help
chriswallace187
Gold - Posts: 1,661
Posted: November 08, 2008 at 11:31 AM / IP Logged
The yellow ignition wire isn't necessary unless you've got an alarm that's controlling the 561T, in which case it would go to the alarm's Ignition input which would no longer go to the car's ignition wire.
GWR goes to the blue (-) status output from the 561T.
Also PKT2 is the wrong firmware(it's for Toyotas). The correct one is PKH2.
C Renner's Auto Electronix
new_leaner
Member - Posts: 14
Posted: November 08, 2008 at 2:37 PM / IP Logged
thanks a lot, I still have one more question. I read back and forth the installation guide but I don't see any instruction how I can use my current transmitter to start remotely after finish installing 561t. How can I do this ?
thanks again
chriswallace187
Gold - Posts: 1,661
Posted: November 09, 2008 at 2:43 PM / IP Logged
What were you planning on using to activate the 561T? It's designed to work when it sees the required number of pulses on the WHITE/ red(+) or WHITE/ blue(-) wires.
new_leaner
Member - Posts: 14
Posted: November 09, 2008 at 6:09 PM / IP Logged
thanks, I am planning to use the door lock to activate the (-) activation input . Is it ok to activate only one activation input or I have to activate both (-) and (+) activation input of 561t in order to make it starts remotely ?
chriswallace187
Gold - Posts: 1,661
Posted: November 09, 2008 at 11:39 PM / IP Logged
You only need to use one of them, but if for some reason you wanted to use both it would be possible.
I see a few problems with this install assuming you're planning on using the factory keyless remote to activate the 561.
1. Honda's OEM keyless entry stops working when the ignition is turned on, so you wouldn't have a way to remotely shut down the car once it was started.
2. Additionally, you wouldn't be able to unlock with the remote for the same reason if the car was running on the remote start.
IIRC the '98-'02 Accords have a separate keyless entry module, and it MAY be possible to cut the ignition wire going to it without interfering with any other vehicle systems...however I don't say that emphatically. Keyless entry module is probably located high behind the passenger side dash.
As far as your activation input you might also use the lock output from that keyless entry module - I believe it's got a conventional (-) wire for that function.
new_leaner
Member - Posts: 14
Posted: November 10, 2008 at 10:44 PM / IP Logged
thanks to let me know those problem with 561t. I should install a different unit that I can unlock and shut down the car while RS running. Is 562t may be the good one to use ?
chriswallace187
Gold - Posts: 1,661
Posted: November 11, 2008 at 12:34 AM / IP Logged
The problems aren't with the 561T, they're with the Accord. Any aftermarket remote start with keyless entry will resolve them however, including 561R or 562T.
