08 caravan, alarm/remote start wiring
qdaddy
Copper - Posts: 133
Posted: January 17, 2009 at 10:34 PM / IP Logged
yeah u got it
qdaddy
Copper - Posts: 133
Posted: January 20, 2009 at 2:29 AM / IP Logged
so no one has colors or has done a caravan yet                                            thnx
offroadzj
Gold - Posts: 2,043
Posted: January 20, 2009 at 4:09 PM / IP Logged
I dont know colors, but I was searching for parts for an 98 gr. cherokee and found an easier way to work with the ignition. it basically screws into the factory ignition and adds a plug to make wire connections easier... no soldering required. I dont remember which bypass it was, but check out bypasskit.com and xpresskit.com.
HTH
Kenny
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
robertsc
Copper - Posts: 337
Posted: January 20, 2009 at 7:45 PM / IP Logged
check vehicle wiring or use the search function
i checked them both and got all my answers there
qdaddy
Copper - Posts: 133
Posted: February 14, 2009 at 8:57 PM / IP Logged
08 grand caravan new body style with smart key no body with wire colors yet?            tnx
Platinum - Posts: 12,488
Posted: February 14, 2009 at 9:14 PM / IP Logged
The door locks are controlled via canbus. You must use a module to control the door locks.
mikvot
Gold - Posts: 1,043
Posted: February 15, 2009 at 11:49 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES Transponder   See Notes
 12 VOLTS Yellow/red Left of steering column   +
 IGNITION     +
 TACH SIGNAL Dk.Blue w/stripe Any coil   AC
 LOCK Violet/green Driver's kick panel   Multiplex
 Pulse to ground via 330 Ohm resitor.
 UNLOCK Violet/green Driver's kick panel   Multiplex
 Pulse to ground via 100 Ohm resitor.
 DRIVER LOCK MOTOR Tan/green Driver's kick panel   REV POL
 DOMELIGHT / ALL DOORS See Notes Driver's kick panel   -
 Driver front: Violet, Driver rear: Violet/gray, Passenger front: Violet/white, Passenger rear: Violet / YELLOW. Note driver's side and passenger side are located in seperate harnesses in the DKP. These independent doorpins must be diode isolated, see diagram.
 TRUNK PIN Violet Driver's kick panel   -
 PWR SLIDING DOOR (DRIVER SIDE)  At BCM in driver's kick panel   -
 Apply ground pulse through 1.5K Ohm resistor.
 PWR SLIDING DOOR (PASS SIDE)  At BCM in driver's kick panel   -
 Apply ground pulse through 2.7K Ohm resistor.
 BRAKE SWITCH WHITE/ green Driver's kick panel   +
 PARKING LIGHTS WHITE/ violet Driver's kick panel   +
 PARKING LIGHTS (-) WHITE/ brown At switch   Multiplex
 Ground via 1K Ohm resistor.
 HORN GREEN/ violet Steering column harness   -
 CANBUS HIGH WHITE/ blue 12-pin connector at ignition switch
 CANBUS LOW WHITE/ brown 12-pin connector at ignition switch
Available Notes
Vehicle Notes
Installation of a remote starter on this vehicle requires the use of an OEM data interface module and requires a custom modification to the ignition switch of the vehicle, see attached diagram. Contact your distributor for data interface module availability.
Based on the combined feature set of the remote starter and the data interface module, certain wiring connections detailed above may not be required. Proceed with caution.
Additional Notes
N/A
Personal Notes
N/A
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
