astrostart 2006 hood pin program
tbroxie
Posted: November 15, 2008 at 8:38 PM / IP Logged
I have a 2000 Ford Excursion Diesel with an Astrostart 2006 installed. I purchased a new remote and programed it using dip switch 8 up procedure. I Also replaced the magnetic hood pin switch with a standard grounding type with a 10K resistor. The truck starts with the hood open or switch grounded. I require the level (3 ?) program for the dip switches. Is it the same as an Astrostart 2100? which requires diesel, glow plugs + or -, ignition on between cranks and hood pin normally closed when hood is opened. The Astrostart 2006 installation  manual would help. Thank you.
pat231
Member - Posts: 9
Posted: December 08, 2008 at 5:35 PM / IP Logged
Different 2006 modules were manufcature. Is it written in Blue, in Black or is it a 2006A?
Let me know i'll get the right guide for you.
PatG
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
