Alternator Whine
GMC4x4Guy
Copper - Posts: 117
Posted: June 03, 2002 at 2:07 AM / IP Logged
I just finished installing a high-end competition sound system in my car. I've installed several sound systems before but never had a noise problem, until now. I have a case of the dreaded alternator whine. I grounded every component, including the deck, to one location, so I figured that ground loops are not my problem. I'm using scoche RCA cables and they never touch any power wires. I have a few RCA cables running a foot away from my power/ground distribution center, but I don't think that's close enough to be my problem. I guess I don't have enough experience with this problem because I am at the end of my road. Please help!
"Drive it like you stole it"
Big Dog
Gold - Posts: 1,265
Posted: June 03, 2002 at 2:21 PM / IP Logged
Hey GMC4x4Guy,
Am I to assume it's in a GM?  You might have one or more diodes broken down in the alternator take it to a shop for tests.  There are also several tests you can do first.  Unplug the RCA's from amp then short the center pin and shield of every input to amp.  Is it better?  Then amp and its wiring is O.K.  The noise could be RF induced meaning a component such as head unit or EQ is picking it up "through the air" try moving the component away from dash if it reduces then shielding might be necessary.  If it doesn't change then it's coming down the line somewhere.  Unplug the antenna.  Is it better?  If so then cut the shield or replace it.  Unplug your EQ and plug amp directly to radio. Is it better?  Probably the EQ's at fault - poor isolation or cracked PC board.  You can also try removing the shield at the connector before it enters amp, at times certain RCA's which have the shield isolated from the connector take care of this problem.  Hope this helps!
Prepare your future. It wasn't the lack of stones that killed the stone age.
NyxBass
Silver - Posts: 226
Big Dog
Gold - Posts: 1,265
Posted: June 07, 2002 at 11:48 AM / IP Logged
Hey NyxBass,
Why did you tell him "Try this for starters:" when he has alternator problems?   Alternator Whine - Last Post -- posted image.
Just kidding! Alternator Whine - Last Post -- posted image.  Hey it's Friday!  Alternator Whine - Last Post -- posted image.
Platinum - Posts: 12,488
Posted: June 07, 2002 at 12:45 PM / IP Logged
Good one Big Dog !! Alternator Whine - Last Post -- posted image. I like that.....
Are you the same Big Dog as in Metra moderator forum  ? Just curious ??
Big Dog
Gold - Posts: 1,265
Posted: June 07, 2002 at 2:52 PM / IP Logged
Hey Jeff,
No, that Big Dog's been neutered!  Alternator Whine - Last Post -- posted image.
