2006 kia sedona, keyless/remote start
sroake4
Member - Posts: 11
Posted: November 21, 2008 at 8:06 AM / IP Logged
Does anyone have wiring information applicable to keyless r/s in an 06 Sedona ? Is it different from 05 ?
stever
chev104275
Gold - Posts: 1,436
Posted: November 21, 2008 at 10:42 AM / IP Logged
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Remote Start
Battery WHITE AND YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN (+) IGNITION SWITCH HARNESS
Accessory 1 BLUE (+) IGNITION SWITCH HARNESS
Accessory 2 PINK (+) IGNITION SWITCH HARNESS
Starter 1 ORANGE (+) IGNITION SWITCH HARNESS
Anti-Theft Type TRANSPONDER IN KEY
Anti-Theft Descript NOT ALL SEDONA'S HAVE THE TRANSPONDER.
Key Sense WHITE (-) 6 PIN CONNECTOR NEAR IGNITION SWITCH HARNESS
Neutral Safety GREEN (-) AT GEAR SELECTOR SWITCH
Tachometer PINK (AC) INSTRUMENT CLUSTER PIN #10
   ALSO WHITE AT PCM IN 61 PIN PLUG #61
Speed Sense WHITE/ BLACK (AC) INSTRUMENT CLUSTER PIN #9
   ALSO AT FAM IN 60 PIN PLUG #3 OR AT DIAGNOSTIC CONNECTOR PIN #6 (WHITE/ BLACK)
Low Crr. Pk Lights BLUE (-) AT SWITCH
   OR PIN #69 IN 72 PIN PLUG AT IPM
Brake Lights WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) RAM MODULE
   PIN #19 OR 20 (40 PIN PLUG)
Horn YELLOW (-) IN 12 PIN CONNECTOR AT STEERING COLUMN
   OR PIN 32 AT IPM (YELLOW)
Modules
WIRE LOCATION
Module 1 PCM - POWERTRAIN CONTROL MODULE - UNDER RADIO UNDER CENTER CONSOLE
Module 2 IPM (INSTRUMENT PANEL MODULE) DRIVERS SIDE FIREWALL
Module 3 RAM (REAR AREA MODULE) IN REAR DRIVERS QUATER PANEL
Module 4 FAM (FRONT AREA MODULE) BEHIND HEADLIGHT UNDER HOOD
Doorlocks/Windows
Door Lock Circuit DATA BUS
Databus Wire DATA BUS WIRES RUN ACROSS THE TOP OF THE DRIVERS SIDE FUSE BOX
Power Unlock RED (-) IN DRIVERS DOOR
   MUST 5 WIRE DRIVERS DOOR MOTOR UNLOCK WIRE TO GET DRIVERS DOOR TO UNLOCK
PowerLock ORANGE (-) IN DRIVERS DOOR
Driver Mtr Unlock PINK (+) IN DRIVERS DOOR
   PIN #C10
Driver Mtr Lock BLUE (+) IN DRIVERS DOOR
Pas Mtr Unlock PINK (+) IN PASSENGER DOOR
   PIN #C10
Pas Mtr Lock
   PIN #C1
LF Window Up BLUE (REV) AT DRIVERS DOOR WINDOW SWITCH
LF Window Dn WHITE (REV) AT DRIVERS DOOR WINDOW SWITCH
RF Window Up RED / YELLOW (REV) AT DRIVERS DOOR WINDOW SWITCH
   THE BLUE WIRE AT THE PASSENGER DOOR WINDOW SWITCH MAY ALSO BE USED.
RF Window Dn GREEN (REV) AT DRIVERS DOOR WINDOW SWITCH
   THE WHITE WIRE AT THE PASSENGER DOOR WINDOW SWITCH MAY ALSO BE USED.
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
REMOTE START
sroake4
Member - Posts: 11
Posted: November 21, 2008 at 11:13 AM / IP Logged
Thanks much!
stever
