remote starter, 05 town and country
bartho
Posted: December 06, 2008 at 10:04 AM / IP Logged
I am having some problems with a starter installed in an 05 Chrysler Town & Country. The vehicle will start but within 1/2 second of starting it will shut down. It seen the ignition is shutting off.
Installed is a Viper 571XV with a XK532 using CHDL6+.
Install Guide:
https://www.the12volt.com/installbay/file.asp?ID=548
Any help with this would be greatly appreciated.
Mike M2
Platinum - Posts: 2,652
Posted: December 06, 2008 at 10:45 AM / IP Logged
Try placing the key in the ignition without turning it on. Does it RS then? If so the bypass is the issue....
Mike M2
Tech Manager
CS Dealer Services
bartho
Posted: December 06, 2008 at 11:04 AM / IP Logged
If I put the key in the ignition it still does not stay running. It does not seem to be a bypass issue.
Just as the car begins to shut off, the dash lights power off. It is the same as what would happen if I was running the vehicle with a key and turn the key off.
The starter will attempt to start it three times and then quite.
Mike M2
Posted: December 06, 2008 at 4:44 PM / IP Logged
Does the starter disengage? Rs it with the key on and it should stay running. Listen for the starter staying on as this will shut the RS down just after starting.
Mike M2
Tech Manager
CS Dealer Services
