06 f150 door trigger
ttornado
Posted: December 15, 2008 at 2:41 PM / IP Logged
Hello I searched all i could with no results. I am installing a code alarm, alarm/starter in a 2006 Ford F150. I have found the door trigger wires in the drivers side sills however i see multiple of the same color wire and when I test with a voltmeter i do not get any voltage.
I was planning on isolating each wire but i am unable to confirm which wires are correct and if they are positive or negative triggers.
Thanks for your help.
soundnsecurity
Gold - Posts: 2,720
Posted: December 15, 2008 at 2:49 PM / IP Logged
DONT hook up any wire if you cant confirm that it is the door pin. i did one of these and did the same thing you are doing. i couldn't find the doorpin so i just used the wire that i was "sure" of without testing it and it turned out to be something dealing with the fuel system. after installing the truck would run for a minute and then quit and wouldn't really run far. it took a trip to the dealership to get it fixed but luckily i had done the owners' friend's car the day before and he knew people at the dealership that took care of it for me. LUCKY
chev104275
Gold - Posts: 1,436
Posted: December 15, 2008 at 5:13 PM / IP Logged
ive used the black and blue in the drivers kick its a positive trigger    if you want individual triggers they should be at the BCM in the back of the cab behind trim panels on the left side
L/F Latch is BLACK / YELLOW pin 4 negitive trigger
R/F Latch is BLACK/ pink pin 5 negitive trigger
L/R Latch is BLACK/ lt blue pin 12 negitive trigger
R/R Latch is BLACK/ White pin 13 negitive trigger
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
