alarm/starter on 08 tiburon
jinstall
Copper - Posts: 67
Posted: December 17, 2008 at 7:18 PM / IP Logged
hey I'm about to venture into this on an 08 tiburon and the only site I can find info from is staub. even directechs new updated site has no info, so wondering if anybody has any other info to cofirm with? of course I'll be testing every wire I hook up, but it'd be nice if somebody else had a source to confirm with. the car is standard as well
Mike M2
Platinum - Posts: 2,652
Posted: December 17, 2008 at 9:01 PM / IP Logged
Here's what AVOX has...
BatteryRED(+)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Ignition 1RED(+)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Ignition 2PINK(+)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Starter 1WHITE(+)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
alarm/starter on 08 tiburon - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE ECM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
alarm/starter on 08 tiburon - Last Post -- posted image.Key SenseBLUE/ORANGE(-)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.TachometerWHITE/ BLACK(AC)ECM MODULE IN PASSENGER KICKPANELalarm/starter on 08 tiburon - Last Post -- posted image.
alarm/starter on 08 tiburon - Last Post -- posted image.Crankshaft SensorORANGE(-)AT ECM MODULE IN PASSENGER KICKPANELalarm/starter on 08 tiburon - Last Post -- posted image.
alarm/starter on 08 tiburon - Last Post -- posted image.Camshaft SensorBROWN(-)AT ECM MODULE IN PASSENGER KICKPANELalarm/starter on 08 tiburon - Last Post -- posted image.
alarm/starter on 08 tiburon - Last Post -- posted image.Speed SenseBROWN(AC)ECM MODULE IN PASSENGER KICKPANELalarm/starter on 08 tiburon - Last Post -- posted image.
alarm/starter on 08 tiburon - Last Post -- posted image.Parking LightsBLUE/ORANGE(-)IN HARNESS AT VEHICLE PARKING LIGHT SWITCH
alarm/starter on 08 tiburon - Last Post -- posted image.Brake LightsWHITE(+)AT SWITCH ABOVE BRAKE PEDAL
alarm/starter on 08 tiburon - Last Post -- posted image.Reverse LightsGRAY(+)AT BCM MODULE BEHIND FUSE PANEL BEHIND DRIVERS SIDE DASH
alarm/starter on 08 tiburon - Last Post -- posted image.HornGREEN/ BLACK(-)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Anti Theft RXBLACK/ ORANGE(-)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Anti Theft TXYELLOW/ORANGE(+)IGNITION SWITCH HARNESS
alarm/starter on 08 tiburon - Last Post -- posted image.Rear DefrostBLUE/BLACK
Mike M2
Tech Manager
CS Dealer Services
jinstall
Copper - Posts: 67
Posted: December 20, 2008 at 7:09 PM / IP Logged
hey guys. running into snags. firstly my setup goes into reservation perfectly every time, tach has been learned, and my bypass is in and everything appears to work correctly. except the car will not crank. there's voltage on the crank wire and everything. even with a key in the ignition there is no crank. what could be wrong?
I found that the crank wire coming off the key cyliinder is pink instead of white, but the crank wire is always gonna be at the key cylinder isn't it? unless it's multiplexed of course, but it doesn't make sense for that to be the case if all the other key positions have dedicated wires. any ideas? I'm pretty much stuck.
jinstall
Copper - Posts: 67
Posted: December 20, 2008 at 7:14 PM / IP Logged
so you know I'm using a dei 556uw bypass
dre187
Copper - Posts: 129
Posted: December 20, 2008 at 10:25 PM / IP Logged
what kind of remote starter are you using and if the starter doesn't have a manual option, are you using the 689 manual module from directed?
tedmond
Gold - Posts: 4,610
Posted: December 20, 2008 at 10:27 PM / IP Logged
it should be at the ignition cylinder. did you even test the wires? or just read what the diagram said and connected away.
jinstall
Copper - Posts: 67
Posted: December 20, 2008 at 10:37 PM / IP Logged
yeah I tested but at the time I couldn't think of anything else but maybe I got the wrong wire. anyways thanks for the suggestions but I feel stupid I just hooked up the clutch wrong. it's a positive clutch and I fed it a negative. I pretty much have it.
thanks to all
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
