line output converter location?
ernk29
Member - Posts: 33
Posted: December 24, 2008 at 6:32 PM / IP Logged
Are there any alternative to hooking up a line output converter other than the rear speakers? can it be hooked on the front door speakers?
Platinum - Posts: 13,726
Posted: December 24, 2008 at 7:49 PM / IP Logged
you can connect them to either pair of speakers.  Of course only if the front door speakers are full range speakers.  It is best to connect them behind the radio, if the speaker outputs of the system are behind the radio.  If we knew what kind of vehicle you had, we could even tell you what color the wires would be.
ernk29
Member - Posts: 33
Posted: December 24, 2008 at 10:40 PM / IP Logged
i have an 2008 chevy colorado with tweeters in the front and onstar
Posted: December 25, 2008 at 12:19 AM / IP Logged
You will probably want to connect the LOC to the rear speakers in that vehicle.  I am pretty sure that the Door Chime and the OnStar come out of the front left speaker of that vehicle.  If you connect it to the front speakers, the door chime will be extremely loud through whatever speakers the amplifier is connected to.
ernk29
Member - Posts: 33
Posted: December 25, 2008 at 12:45 AM / IP Logged
well if the door chime is only in the left front, what would happen if i did the right front? And i've never hooked a line output converter before, do i just splice whatever speaker's wires i use?
Posted: December 25, 2008 at 1:07 AM / IP Logged
Stereo means 2 separate channels.  That is how you get stereo separation.  If you use only one speaker to feed both sides of your LOC, you will not get all of the available information.
line output converter location? - Last Post -- posted image.LF Speaker (+)TAN
line output converter location? - Last Post -- posted image.LF Speaker (-)GRAY
line output converter location? - Last Post -- posted image.RF Speaker (+)LIGHT GREEN
line output converter location? - Last Post -- posted image.RF Speaker (-)DARK GREEN
line output converter location? - Last Post -- posted image.LR Speaker (+)BROWN
line output converter location? - Last Post -- posted image.LR Speaker (-)YELLOW
line output converter location? - Last Post -- posted image.RR Speaker (+)DARK BLUE
line output converter location? - Last Post -- posted image.RR Speaker (-)LIGHT BLUE
