2006 pontiac g6, hardwire radio
saranykm
Member - Posts: 23
Posted: December 26, 2008 at 10:41 PM / IP Logged
2006 pontiac g6 sedan, non amplified radio, just a basic cd player no onstar either
uncessful in my search, so here is my question, has anybody hard-wired an afermarket radio to one of these? if so, did you lose the door chime, and other features that you would loose if you dont use the C2R-GM111b?  also, is there a wiring diagram for the car itself???? i did find one for the 2005 cobalt i assume they would be the same, but who knows.
one more question, is teh V2R-GM11b the only option to use on this car???
thanks in advance...
sm
gorilla
Platinum - Posts: 13,726
Posted: December 27, 2008 at 12:40 AM / IP Logged
You will lose the chime functions. You will have to find a switched 12 volt source in the fusebox. I feel your pain about having to shell out the 100 bucks or so for the adapter. If you insist on hard wiring it, make sure you cut it far enough back so you can reconnect the harness to put the factory radio back in the car.
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / WHITE          (+)          RADIO HARNESS
     Accesory
     Ground          BLACK/ WHITE          (-)          RADIO HARNESS
     Power Antenna          PINK          (+)          RADIO HARNESS
     LF Speaker (+)          TAN
     LF Speaker (-)          DARK GREEN
     RF Speaker (+)          DARK GREEN
     RF Speaker (-)          LIGHT GREEN/ BLACK
     LR Speaker (+)          BROWN / WHITE
     LR Speaker (-)          BROWN
     RR Speaker (+)          DARK BLUE
     RR Speaker (-)          TAN
     Amp Location          MOUNTED UNDER REAR DECK
     Steering Cntrls          OPTIONAL
     Speed Cntrl          YES
     Radio Security          YES
saranykm
Member - Posts: 23
Posted: December 27, 2008 at 8:47 AM / IP Logged
thanks for the info.... i know i can count on the 12 volt for help!!!!
gorilla
