where to buy hidden advancedkill switch
4thephil
Member - Posts: 14
Posted: December 28, 2008 at 3:18 PM / IP Logged
I am looking for a kill switch to be put under a secret button of my dashboard, or in my door panel where I have to hit window down (or something similar). The only thing I've found like this is here:
http://www.bypasskit.com/product.aspx?prodid=LD120&catid=10
But you can't buy it there, BAH!
Chris Luongo
Platinum - Posts: 3,746
Posted: December 28, 2008 at 3:32 PM / IP Logged
You could make something with a relay, it wouldn't be that hard.
But, try to find this part number: AU-SI-N, made by Omega. That'll do just what you want.
It even has a way to pop in another relay, that'll cause the horn to honk during an unaothorized start attempt.
4thephil
Member - Posts: 14
Posted: December 28, 2008 at 3:41 PM / IP Logged
I will be having this installed by a professional, I won't do it myself - mainly because I want it hidden REAL well. Do you think they'll have things like this, or must I make it/buy the parts from a Radio Shack and then bring it to the professionals?
ckeeler
Gold - Posts: 1,461
Posted: December 29, 2008 at 12:09 PM / IP Logged
pros will already have the parts.
tedmond
Gold - Posts: 4,610
Posted: December 29, 2008 at 1:49 PM / IP Logged
pro installers will for sure have relays, wires, switches on hand, but it will take them some time to rig something up.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 29, 2008 at 7:59 PM / IP Logged
"Pros" ..... I love that term! where to buy hidden advancedkill switch - Last Post -- posted image.
tedmond
Gold - Posts: 4,610
Posted: December 29, 2008 at 8:44 PM / IP Logged
see if a local shop that deals with DEi can order it for you.
4thephil
Member - Posts: 14
Posted: December 30, 2008 at 4:28 PM / IP Logged
I appreciate all your responses. I think I am going to go the Ravelco way ($400 installed, will drive to my home to install). In turn, it will cut 2 circuits of my choosing, installed under the hood, and car will only star if the plug is in in the car as well. It says it's never been cracked/hotwired, and says that 90% of cars stolen are hot wired vs. towed. Im leaning towards the Ravelco vs standard kill switch as it is under the hood and better hidden, and vs. $300 alarm w/ dedicated battery as that can just be disabled + no one even looks when an alarm goes off.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
