troubleshoot amp on fire
cutlass013
Copper - Posts: 95
Posted: December 12, 2008 at 4:58 PM / IP Logged
Hey all I have two type x 10 subs and 2 kicker (remanufactured amps...sadly) 1000.1 i have a ported box I built my self and here is the problem
I had it wired to 2 ohms according to alpines manual for the amp with gain maybe at 2 or 3(no bass at 1) and it was getting really warm... sounded good and loud and clear then they cut out i get a beeeeeep and the protection light came on... it does come back on as i have now wired it down to 8 ohm and with a temps gun hits around 190F while working good after being warmed up... is this to high and is the amps crap? I have another amp im going to try to see if its the same thing as i only have one amp and sub hooked up....
0ga power and ground
12-14 gauge amp to speakr(to small be the problem??)
wired in 2 or 8 ohms in 8 gain has to be half way up for it to sound right....??
any help is appreciated
cutlass013
Copper - Posts: 95
Posted: December 28, 2008 at 6:47 PM / IP Logged
So i have a kicker 1000.1 and a alpine type x actually two but one one set hooked up i have had 0 gauge wire for power in there barely and the amp has been running warm and overheated at 2 ohms.. them amp should handle that but i switched it 8 ohm and ran cooler but still overheated after normal usage... tonight i thought maybe a bad ground so i switched the ground over and amp wouldnt come on then i changed the ground wire to a smaller wire to fit in terminal better then turned it on amp came on popped then went into pretection then cut off and caught on fire along the heat sink.... any ideas?? i have another amp and sub i havent tried but im scared to burn that one too????
sub is dvc 4 ohms-can be wired 8 or 2 ohms
sub is kicker 1000.1 should be 2 ohm stable
wire between amp and speaker is around 10 gauge ??
any ides?
Platinum - Posts: 13,726
Posted: December 28, 2008 at 7:21 PM / IP Logged
The power supply of your amplifier is toast.  It was probably caused by shorted output transistors.  150 to 200 dollars to get it repaired.
cutlass013
Copper - Posts: 95
Posted: December 28, 2008 at 7:28 PM / IP Logged
so is that a hook up error or would that be an amp defect?
forbidden
Platinum - Posts: 5,354
Posted: December 28, 2008 at 9:14 PM / IP Logged
Could be a bad ground error.....
cutlass013
Copper - Posts: 95
Posted: December 29, 2008 at 3:28 PM / IP Logged
wouldnt a bad ground set off the protection light?? i mean techinically the light did come on but shortly then boom........
DYohn
Platinum - Posts: 10,741
Posted: December 29, 2008 at 3:52 PM / IP Logged
Could be either one.  Was the amp new?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 29, 2008 at 8:06 PM / IP Logged
Yup, the amp being refurbed was more than likely the issue.
Refurbed when and where (by whome) ? Joes discount amp repair?
